Differiential Fluids
Old Oct 4, 2010 | 05:48 AM
action.is.go's Avatar
Default Differiential Fluids
I was wheelin' all wknd and to say that I went thru a few deep water crossing would be an understatement. I'm sure the breather tubes were submerged a few times. This brings me to my question...What type of fluid/oil are you guys/gals using in your diffs? I'm planning on changing the fluids and greasing all my nips once I've cleaned her up a bit, as she's a little muddy. Thanks in advance
Old Oct 4, 2010 | 06:09 AM
pontiacstogo's Avatar
Good write up with oil recommendation here;
http://project-jk.com/jeep-jk-write-...hange-write-up
Old Oct 4, 2010 | 08:19 AM
Coley's Avatar
How deep were you going?
I thought the stock tubes came up to about the same level as the intake. You'd have to be almost 3 feet deep to come close to the tubes.
The_Yeti's Avatar
I personaly use Royal Purple its a bit pricy but i feel you pay for quality
Old Oct 4, 2010 | 08:33 AM
cbeas's Avatar
I used Mobil 1 in the rear & Valvoline Durablend in the front. I was going to use Royal Purple but the parts store didn't have the weight that I needed. In fact the durablend was the only 80w90 they had in stock. Seems to be an odd weight but that's what my owners manual calls for in the front.
Old Oct 4, 2010 | 09:15 AM
cwargo's Avatar
I put Mobil 1 in the front and back (just did it a couple of weeks ago)
easy to do - a bottle pump would have helped out on the front
Old Oct 4, 2010 | 09:26 AM
I wouldn't say all the water/mud holes were 3 ft deep, however, some were definitely. Friday night we pulled a stock Rubi out of 3+ ft, driver of that Rubi blow his clutch out, and was stranded for 2 days prior to our arrival.
Old Oct 7, 2010 | 04:59 PM
alexo's Avatar
Mobil 1 75W-90 Synthetic Gear Lube, replaced the original @ 5000 miles
Old Oct 8, 2010 | 08:24 PM
RA032726's Avatar
Banned Member
x2 on the Mobil 1 and replaced mine at 10,000.
Old Oct 9, 2010 | 04:14 AM
jeeperjkjeeper's Avatar
Amsoil synthetic for diffs , transfer case and tranny!
ID:	94091   Click image for larger version
