Dumb question, but what is the correct way to use the factory jack?
Old Apr 27, 2011 | 07:50 AM
Mark Doiron's Avatar
Originally Posted by Shankspony
... A floor jack is impracticable and usually not tall enough. Any suggestions? ...
One of these will fit under the rear seat of a four door, and still permit folding down the 60% side while leaving the 40% side up. It's what I carry. And a couple 4x6s to reach a little higher. You can also use a tie down strap to secure the axle so it doesn't droop if you decide to jack by the frame.
http://www.craftsman.com/shc/s/p_10155_12602_00950523000P?vName=Power+Tools+%26+E quipment&cName=Equipment&sName=Mechanics+Equipment &keyword=floor+jack&prdNo=1&blockNo=1&blockType =L1
Old Apr 27, 2011 | 01:36 PM
JK-UTE's Avatar
Originally Posted by RedJK2
Personally, I think the stock jack is better than no jack. And it's normally only used for emergency purposes.
Touche.... I agree 100%
Old Apr 27, 2011 | 01:41 PM
pettym's Avatar
if you can find a place to stick it, these things are awesome
amazon.com/Powerbuilt-640912-3-Ton-Bottle-Stand/dp/B003ULZGFU
Old May 6, 2011 | 08:59 PM
jcrcan25's Avatar
Default jack
Originally Posted by Biginboca
I have been using the factory jack under the axles on the axle tube itself in no particular spot, or sometimes under the pumpkin(s). But I noticed the jack has a cut out in the center as though it would fit over or into something so I wondered if I was doing it right?
pick it up with 2 hands and throw it away..... and buy a highlift...... if you have any lift or larger tires....the factory is totally useless
Old May 9, 2011 | 09:26 AM
CreepyJeeper's Avatar
too funny!
