E-Disco will not re-connect
Went wheeling in Colorado where it broke, and spent a day and a half trying to get it fixed. When I got home, I went to post on here and saw that TF now was giving away extended rear links and recommending the old rears move to the front.
Guess I wasn't just seeing things...
When I put in my teraflex BB, I did have extensions for the rear and put the factory rear links in the front, Are there longer ons for the front that teraflex would send me? or is this the correct set-up?
Well tried all this, Except for disconnecting battery(I want dealer to see the problem for warranty) and nothing worked, I did not open it up either, I'll wait for warranties to be up before.
Even at higher speeds it does not connect.
I try to keep safe while driving, but yesterday I had it fishtail a bit going around a roundabout on wet pavement. It caught me by surprise!
Guess I'll have to be careful t'ill next Monday!
Once again, thanks for the help
No. When they originally came out they didn't come with extended rear links. They added them when people complained about the fronts being too short. You are fine.
I have had heaps of trouble with mine so i stripped the thing and relubed it with never seize grease and put a thrust washer between the end of the motor and where it makes contact with the little sliding collar set up.., now as long as i'm in 4wd when i turn it on and do a wiggle in my seat it will let go with a little click and reconnect the same way
Also it's speed limited, if you have it disconnected and go over about 15MPH it'll reconnect (SWAY BAR will flash on the dash) and then let go again when you slow down again (SWAY BAR steady)
only one more drama to solve the electrics for it aren't water proof so if you go swimming with it it stuffs up until you pull the plug and dry it.
Ado
Ado
Thanks
