Electronic Disconnect seems to be acting funny....
Old Sep 4, 2010 | 07:14 PM
mmacJK's Avatar
Default Electronic Disconnect seems to be acting funny....
Ok
So today i popped on the disconnect and the light for the swaybar just kept blinking. Randomly it would go solid for a few minutes and then blink again...
Any ideas, ive never seen this before..
Old Sep 4, 2010 | 07:41 PM
ronjenx's Avatar
What t-case range were you in?
How fast were you going when it was blinking?
How fast were you going when it went solid?
Old Sep 4, 2010 | 08:01 PM
mmacJK's Avatar
Hey
I have a standard and had it in Lo High
Hmmm... I suppose i was going anywhere from 20-30. I think it may have been blinking throughout the range but cant say that for sure....
I do believe it was solid at times in the 10-20 range. Again, i cannot say for sure
Is there a speed limiter to the disconnect? If there is i was unaware.
Old Sep 4, 2010 | 08:05 PM
Sunnysideup's Avatar
JK-Forum Ambassador
In the owners manual ... I believe it is limited by speed, I don't remember but I think it was around 15 that it will no longer stay disconnected!
Old Sep 4, 2010 | 08:06 PM
joe002's Avatar
Originally Posted by mmacJK
...Is there a speed limiter to the disconnect? ...
Yeah, it tries to re-connect at 18mph.
ronjenx's Avatar
From the owner's manual:
The system monitors
vehicle speed and will attempt to reconnect the
stabilizer bar at speeds over 18 mph (29 km/h). This is
indicated by a flashing or solid “Sway Bar Indicator
Light.” Once vehicle speed is reduced below 14 mph
(22 km/h), the system will once again attempt to
return to off road mode.
Old Sep 4, 2010 | 08:07 PM
mmacJK's Avatar
Dudes,
you rock
I had never used it before on a dirt road was just playing with it and noticed this.
The system monitors
Old Sep 4, 2010 | 09:11 PM
dfe's Avatar
dfe
About three weeks ago mine I pressed the button in low range, it started flashing and has not stopped since, been waiting for the dealership for two weeks now for a replacement, sounds like Chrysler is not too happy due to the cost of the unit.
Have no idea what is wrong, but dealership said the entire unit must be replaced.
(2009 4dr)
