Esp bas light help
Old Apr 12, 2011 | 05:39 PM
NJ-RUBICON's Avatar
Default Esp bas light help
The ESP BAS light and skidding light has been on for two weeks now and I can't figure out how to turn it off. Any one know what the deal is. Also the steering wheel is turned to the right. This is after a offroad trip. Help plz
Old Apr 12, 2011 | 05:59 PM
mkjeep's Avatar
http://project-jk.com/jeep-jk-write-...-end-alignment
recenter your steering wheel
Old Apr 12, 2011 | 06:10 PM
PainKiller's Avatar
x2 on re-centering your steering wheel.
Old Apr 12, 2011 | 06:56 PM
08yellowx's Avatar
look for something bent before recentering the steering wheel.
Old Apr 12, 2011 | 07:46 PM
Jgmz82 OIIIIIO's Avatar
Same exact thing happened to me. I just installed a suspension lift and my steering wheel was off center. and the trac control bc I had to get the comp recalibrated for the size tires and gear ratio I had... hope this helped
Old Apr 23, 2011 | 02:22 PM
Mud Pie's Avatar
Same thing just happened to my 2008 2-Door. ESP and BAS lights came on and stay on.
Just put a 3" lift on less than two months ago. My steering wheel seems very straight. How far off does it have to be to cause this issue?
Old Apr 23, 2011 | 06:54 PM
Vin's Avatar
Vin
Well you have a 3" lift so your axles are probably off-center. Do you have an adjustable track bar?
Old Apr 23, 2011 | 07:06 PM
rocNrow's Avatar
Mine come on intermittingly, usually in high winds.
Old Apr 23, 2011 | 07:08 PM
littlewhite's Avatar
Soon as you correct the steering wheel it will go off after a few miles of driving. I had the same problem even after my gears and tire size were corrected. If you have a procal tuner or something it will take care of it.
Old Apr 24, 2011 | 10:08 AM
Mud Pie's Avatar
Yes, my FT 3" Long Arm kit is fully adjustable. I also have a ProCal unit that could help center wheel..
Drove the jeep today and lights went off and stayed off. I'll see if it repeats and make adjustments accordingly.
