Exhaust vibration..
Check the exhaust cross member that runs in front of the transmission cross member. It has a heat shield that is spot welded to the exhaust pipe. one or two of the spot welds will break loose and cause a vibration that sounds like it is coming from the passenger side floor.
This is exactly the problem. My sister's 07 had this issue, if you don't have access to a welder or don't want to pay for it (like me ) I fixed it by using a big flat screw driver and using it to separate the shield from the pipe. All you need is really little clearance between the two and the noise will go away .
