gas mileage!!
Old Dec 8, 2010 | 10:32 AM
evw08jk's Avatar
Default gas mileage!!
Just got an 08 2 door x. It is bone stock. I put $50 in gas in the tank at aroung 3.25/gallon. I only got 150 miles out of it. Its a 6 speed, i always shift before 3,000 rpms. Never in 4wd . Is that normal !?
Old Dec 8, 2010 | 10:37 AM
mpkelley20's Avatar
There are a ton of threads on reported gas mileage here. But based on your stats, you got about 9.75mpg...that seems way low considering you have a manual and are bone stock. However, what kind of driver are you? heavy on the pedal? Are you running heat? Cold outside? Letting the jeep warm up a lot (i.e. sitting idleing a long time)? Drive hilly roads? Check the oil and make sure its not sludge. Are you carrying a lot of extra weight? what's your tire pressuer? tire tread?
Lots of questions....
Old Dec 8, 2010 | 10:38 AM
JK Wes's Avatar
Dude that SUCKS! I have a '07 2 door X, i pay only about 2.80 here though but i get more like 350 a tank....i have a k&n drop in filter that helps some but not 200 miles worth
Old Dec 8, 2010 | 12:25 PM
drumnatural's Avatar
Damn 350 a tank is good. How many gallons go in when u fill it up?
Like posted above thats really bad mpgs. Unless your in 4wd most of the time I don't see how mpgs that low is normal. I don't care how heavy you are on the gas.
I average about 20mpg which equates to just over 300 miles a tank.
Old Dec 8, 2010 | 12:32 PM
Urban Assault Vehicle's Avatar
I have a Unlimited with 35" Mud Grapplers, Power Programer, Automatic, Hardtop, 2.5" lift and I can get about 315 miles to a fill up. Granted I have a larger tank than the two door, but I think I average about 15 mpg. So yeah, you're doing pretty badly.
Old Dec 8, 2010 | 12:33 PM
quinnfrontz's Avatar
idk if it's because it just got cold but mine randomly started getting 10-12 mpg this week, it usually gets around 17
Old Dec 8, 2010 | 12:56 PM
nthinuf's Avatar
I don't have a manual, but shifting up near 3k rpm seems high. Sounds like you like to punch it and go fast, which would explain the shitty mpg's...
Old Dec 8, 2010 | 07:09 PM
JK Wes's Avatar
I usually put in about 16 gals as i try not to be bone dry when i get gas
Old Dec 8, 2010 | 07:25 PM
JKlad's Avatar
You said it's a stock '08 X, but what diff gear ratios are you running? 3.21s were standard for the 6-speed, but 3.73 and 4.10 ratios were also available an an option.
If you've got 3.21s then yeah, you must have a hole in the gas tank or something because bone stock you should be getting at least 15-18MPG from a 2-door 6-speed but city driving with a heavy right foot can see you getting 10 or 12 MPG if you're running 4.10s. Another thing to keep in mind is that it may have had even lower gearing added (eg 4.88s) to compensate for bigger (35 or 37") tires, and the previous owner removed the aftermarket wheels/tires and lift and reverted the Jeep to stock when he sold it; a very common practice. Basically the lower your gearing, the more gas you'll use with stock tire diameters.
Old Dec 9, 2010 | 04:14 AM
Yankee's Avatar
Something is not right. I get better than that with my current setup, even if I do a lot of stop and go.
You should be getting at least 15 mpg average IMO unless you are flooring it from every stop.
