Gear oil question
I do a little towing. A utility trailer with things for my college boy. About 200 miles round trip 2 times per year, maybe a little around town stuff in between. Our local auto part store only had the Royal Purple. 1, 75-90 and 2, 75-140. So I got them for the change. The question, is it a big deal to put the 75-140 even if you're not doing much towing. Any negatives? Thanks
There is one potential negative to using the heavier multi-weight: in cold weather, your JK's e-locker (if so equipped) will sometimes proves finicky with it.
I prefer Mobil 1 75W-90 front and rear. It's less costly than Royal Purple and has a very solid reputation.
I have a permanent hitch. I was just wondering if there are any issues with running a higher number if most of the time I don't tow. If the worse is thicker in colder (I drive at least 1/2 hour to work). I guess I really don't understand how the numbers work where it would be a problem with using it all the time. I would rather be safe then sorry. I plan on keeping it forever.
Like Mobil 1, Royal Purple and Valvoline Syn Blend meet the API GL-5 requirement, so you're OK there. As for the 75/90 or 75/140, you should be OK there also if you use the 75/140, even throughout the winter, unless you're in an area where the temperature reaches below 32* for long periods. The lower number is the viscosity of the oil in cold temperature, and the 140 is the viscosity in hot temperatures. Most likely a rating of 32*-212*. When towing, in summer months, the rear differentail can reach temperatures of 300* or more. That is why the owners manual recommends the 75/140.
With that in mind, however, as was posted by a few, in colder temperatures the 140 can be a bit thick. Seeing that the gears are lubricated by splash, the film would be a bit harder to maintain to start, however once warmed there should be no problem maintaining the lubrication film on the gears.
I run Mobil 1 75/140 in the rear here in SE Pa, and have encountered no problems during the winter months.
Thanks Lorrel.That's what i was looking for. We do get the cold temps and I guess If I just take it easy a few minutes it should warm up fine. It's chicago, we do get stretches of under 32. go figure.
