heated seats not working
Old Mar 19, 2016 | 04:51 AM
DJjeep's Avatar
Default heated seats not working
Hello,
I'm sure you all know the saying happy wife/happy life. The heated seats quit working.
The switch lights up for about two seconds then it goes off. i've checked the fuze its ok
any thoughts on what to do next? It can be cold in Michigan, She wants her seat fixed
Old Mar 19, 2016 | 01:28 PM
Macman1138's Avatar
Originally Posted by DJjeep
Hello, I'm sure you all know the saying happy wife/happy life. The heated seats quit working. The switch lights up for about two seconds then it goes off. i've checked the fuze its ok any thoughts on what to do next? It can be cold in Michigan, She wants her seat fixed
The only thing I can tell you is take it to a dealer. Might cost you, but it will be fixed.
Old Mar 22, 2016 | 08:37 AM
f1ralvk's Avatar
Heated seats?!?!
Old Mar 22, 2016 | 03:45 PM
k9blueline's Avatar
I believe it's a common issue. My 2012 JKU seats don't heat up like they used too either. Haven't taken it to the dealer yet but I believe there is a fix for it.
Old Mar 23, 2016 | 02:49 PM
YJ-JK's Avatar
Originally Posted by f1ralvk
Heated seats?!?!
X2
What had this world come to. If it doesn't work, then it's a jeep thing.
All kidding aside, I get the happy wife angle. I've made a few purchases to keep my better half happy (eg spiderweb shade).
Old Mar 23, 2016 | 03:21 PM
doc5339's Avatar
Veteran: Navy
I have this same issue with my 2013 JKUR Manual, though it seemed to disappear when I reset the Jeep PCM to stock with my AEV ProCal; I did this to install a DiabloSport Trinity tune for my newly installed Magnuson Supercharger. Soon as I reinstalled my AEV ProCal for tire size correction, it started cutting off again.
If I turn-off and re-start the Jeep, the issue goes away.
I do have TrekArmor (Bartact) seat covers, but doubt that has to do with it. I have read that others noticed the same issue with the AEV ProCal, though it may have nothing to do with your particular situation.
Old Jan 13, 2018 | 11:46 AM
BigMike's Avatar
I have the same issue with my 2014 Rubicon. I find it difficult to believe that all 4 elements went out at the same time. I just reflashed the Jeep with the AEV ProCal when I went to 37" tires and 4.88 gears over the summer.
Has anyone contacted AEV about it? I might try resetting the ProCal to stock and see if the heaters work. Then I'll set it for the gears and try and then add the tires and try.
Old Jan 14, 2018 | 09:05 AM
doc5339's Avatar
Veteran: Navy
Default Fwiw
I have not re-flashed with the AEV ProCal, and my heated seats have been working well. I think, at least in my case, the ProCal was the cause. I currently have a custom tune loaded via DiabloSport Trinity T-1000 and an Aeroforce Interceptor ScanGauge (just monitoring fo now, no wheel size changes, etc).
Old Nov 18, 2020 | 08:09 AM
MichaelJDonovan's Avatar
Hello,
I have never seen a Forum request go so wrong in such a short period of time!
Has anyone resolved this issue or has the Part numbers necessary to fix it?
I have the same problem. Start the Jeep, turn on the Driver's side heated seat, will stay on from approx 20 seconds, will not stay on. Then I try again and after about 3 seconds, it turns off.
Side note: the passenger side is fine.
Old Nov 18, 2020 | 03:47 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Heated seats!! Ha I have to fart to make my seats warm
