Help please
Old May 22, 2011 | 01:09 PM
jeep_creep's Avatar
Default Help please
Does any one know how to tighten the front e-brake cable that goes to handle? Mine doesn't get tight till the very top and doesn't hold very good at all, thanks
Old May 22, 2011 | 01:11 PM
glocksrfun's Avatar
I always thought that the e-brake only worked the back brakes.... Good luck.......
I think I see what your saying..... prolly get into the console somewheres if not underneath.. A lot of help I am
Last edited by glocksrfun; May 22, 2011 at 01:13 PM. Reason: Cause I didn't get it.
Old May 22, 2011 | 01:18 PM
Coley's Avatar
When the rear shoes (ebrake shoes) wear enough there's an adjuster that should take up the slack.
Either
A) your adjusters are seized
B) your e-brake shoes are worn down to the limit
You don't adjust anything at the handle afaik.
Old May 22, 2011 | 01:19 PM
jeep_creep's Avatar
Lol, yes it only locks the rear and under the jeep both cables go into the floor in seperate spots, I just don't want to pull my consol all apart to find there isn't an adjustment
Old May 22, 2011 | 02:17 PM
Coley's Avatar
The adjuster is inside each brake drum
Old May 22, 2011 | 02:19 PM
jtjk's Avatar
check project jk, im pretty sure there is a write up on this
Old May 22, 2011 | 02:58 PM
Battlefrog's Avatar
Should be able to find it in here...
https://www.jk-forum.com/forums/show...ery-Newbie-Has
Old May 22, 2011 | 03:20 PM
inverse121's Avatar
Put your jeep in reverse, get rolling along, brake hard. Repeat several times. This will adjust your emergency brake tension.
