Sponsored by:
Sponsored by: DashLynx
HELP! Transmission noise--shifting from R to D and the aftermath
Old 10-27-2014, 09:26 AM
951JEEP's Avatar
Default HELP! Transmission noise--shifting from R to D and the aftermath
JKU- 2007 Sahara auto w/ 35s & 2.5" TF coil lift. 99.5k miles. Programmed with AEV ProCal to compensate for tire height.
I returned from the gym this AM and put the JK in reverse to back into my garage. About half way up (10' @ most) I hear 2 loud "clunks". I stopped and did a walk around. No leaks. Nothing evident of a failure. Got back in and pulled it into the garage.
Evidently enough, I was going to take her down to ORW this morning to have them inspect the front end as I have been having an issue with a shim in the steering (whole different issue). While in the garage, I place the JK into drive, and hear the transmission move into gear. Curiosity spiked. I cycled the transmission from reverse to drive a few times and found a horrible noise. Once in drive, and out of the garage while traveling down the street, the JK makes a horrible noise while accelerating; something like driving over the washboard on the shoulder of the road. It stops while coasting.
I had my wife cycle the transmission from drive to reverse and vice versa. here's a sound clip. Anyone have any ideas as to what is wrong? Anyone experience this before? Im chicken shit to drive it anywhere too far...
http://youtu.be/ai-reI2w_H8 I had the transmission serviced within 10k miles. The shop claimed there was plenty of metal shavings and would appear it might have been its first service. Its ran smooth since. I only had it services because I noticed the gasket began to leak.
Old 10-27-2014, 09:29 AM
Jiblet's Avatar
Have you checked the ATF level?
Any service ever done in trans?
Do you use an auxiliary cooler?
Old 10-27-2014, 09:37 AM
951JEEP's Avatar
ATF level is full.
Serviced within this past year..less than 10k miles ago.
no aux cooler.
Old 10-27-2014, 11:52 AM
951JEEP's Avatar
I should also mention, I do not have any dash lights on either--NO CEL
Old 10-27-2014, 12:11 PM
951JEEP's Avatar
Here's a better quality video that illustrates my problem...
https://www.youtube.com/watch?v=vz26ATLOFuc
Old 10-27-2014, 01:17 PM
Chadc880's Avatar
Lol caravans make that noise
Old 10-27-2014, 06:06 PM
Wrangeler X's Avatar
That's normal.
Old 10-27-2014, 06:16 PM
951JEEP's Avatar
its not normal. It JUST started making this sound this morning.
Old 10-27-2014, 06:51 PM
Jiblet's Avatar
Doesn't sound normal to me, either.
What kind of service did you have done? Just maintenance or was there a problem? Filter and fluid? At a dealer or independent shop?
I'm wondering if someone put in fluid that isn't ATF+4.
How does the fluid look? Bright red? Any burnt toast smell?
Old 10-27-2014, 07:46 PM
951JEEP's Avatar
It was a complete flush. replaced the filter and fluid. At a local shop; ensured it was ATF+4; fluid is clean, bright red...no noticeable smell whatsoever.
Quick Reply: HELP! Transmission noise--shifting from R to D and the aftermath
