Horn isn't working?
SubscribeJK Jedi
Quote:
Good to know...did you use a air compressor to blow out and dry??? This will be one of my jobs today....along with draining my Diff's.Originally Posted by matt852
I cleaned it today to get most of the water out. There is still water or mud in it but it sounds a lot louder than yesterday. Not as loud as stock but okay
Quote:
Nope I just got some clean water and put it in there and shaked it out.Originally Posted by TripleJeep_99
That happened to me. I wasn't able to get all the water out and the horn never sounded the same. I removed the horn and drilled a small hole at the very center of it to drain the LAST LITTLE BIT of water and then plugged up the hole with epoxy putty. Worked like a charm. That was almost a year ago.
Quote:
awesome good tip!Originally Posted by adammj
Quote:
Ok I will have to try that where exactly did you drill the hole? I don't want to accidently screw anything up this is a really good tip Originally Posted by adammj
Quote:
Sent from my Droid
Any chance you could show a picture of where / how you mounted your Hella Horns. I have looked and didn't see an obvious place.Originally Posted by rinkishJK
I ditched my stock one after it got wet n sounded like a dead duck! I like the plastic bag idea!! I got a set of hella horns and its a lot better than the solo JK stocker.Sent from my Droid
Quote:
One is in the stock spot behind driver light...Quote:
Sent from my Droid
Quote:
The other is behind grille on driver side.Quote:
Just used a scrap piece of metal to mount the mount it comes with to.
Sent from my Droid
Quote:
Wait so where did you drill it was it in the very center of the black side?Originally Posted by TripleJeep_99
awesome good tip!
