how do you reset the check engine light
Old May 28, 2008 | 09:28 AM
mackdjm's Avatar
Default how do you reset the check engine light
I had my gas cap stolen and a few days later I replaced it. the next time I started the jeep after replaceing the cap, my check engine light came on. In the book it says that a missing gas cap can cause the check engine light to come on so thats what I'm assuming caused the light. But now that the new cap is on, how do I reset or clear the check engine light???
08 Rubicon Unlimited
Old May 28, 2008 | 09:51 AM
Mark Doiron's Avatar
Originally Posted by mackdjm
... how do I reset or clear the check engine light??? ...
I left my gas cap off the other day, so I used a code reader I own to reset it. I think I've read here on JK-Forum that AutoZone will read and reset your codes for free. You might give them a call.
Old May 28, 2008 | 06:08 PM
round eyes's Avatar
push the button that has your odometer. the error code is seen where the odometer readout is.... so push the button to clear it...
or that is what the manuel says
Old May 28, 2008 | 06:10 PM
Doc_D's Avatar
You can reset it with a code reader.
The gas cap code (gross evap leak) will reset itself after some time (50 miles rings a bell).
Old Oct 3, 2008 | 02:27 PM
JIMMYB's Avatar
WHAT IF THERE ARE NO CODES WILL THAT TURN THE CEL OFF?
Old Oct 5, 2008 | 09:43 PM
TINMAN080's Avatar
The fuel cap code will reset itself. Keep driving for a few ignition cycles.
Old Oct 6, 2008 | 06:54 AM
steelerjeep's Avatar
Anytime the checkengine light comes it will reset itself when ever the condition that caused it to come on stops. It may take a little bit but it will go away.
Old Oct 6, 2008 | 10:11 AM
RevyJKU08's Avatar
What about disconnecting the battery for 10-20minutes should that not reset all the codes????
Old Oct 6, 2008 | 12:51 PM
kyhunter72's Avatar
Talked to a friend of mine at the local dealership. he said the magic number is 20 cycles of the engine. other than using a scanner to reset it be patient if it doesnt reset then there may be another problem causing it
