How much time? (driveshaft
Old Feb 23, 2011 | 12:33 PM
Schwheelz's Avatar
Default How much time? (driveshaft
As you can see from these pictures it appears im having grease spill out of the boot in the upper and lower joints of the driveshaft.. How big of a problem is this? Is this driveshaft failing after only two weeks of its new lift?
3 1/4 inches.. Jk 2 dr
ID:	130419   Click image for larger version
ID:	130420   Click image for larger version
Old Feb 23, 2011 | 12:36 PM
interceptor_1972's Avatar
3 1/4" on a 2-Door is quite a bit of lift and if you haven't already, you should look into getting a new driveshaft. You could continue adding more grease in there with a needle adapter, but your bigger issue is the angle being too steep. That driveshaft is on its way out.
Old Feb 23, 2011 | 12:40 PM
h1ker's Avatar
With a after market DS youll need to make sure your pinion angle is right on the money...Do you have adj arms?
Old Feb 23, 2011 | 12:53 PM
Dronac's Avatar
I had the same boot on the front driveshaft fail after a few months with my lift (2 door). Somehow, I got the dealer to replace it under warranty, although I know it will fail again.
Old Feb 23, 2011 | 01:35 PM
nthinuf's Avatar
Obviously.
It will dry up. Make noise. And then seize. If you happen to be on the freeway at the time, you just lost your tcase and gears as well. So, you can decide just how big of a problem it is to you.
As noted above, that is a decent amount of lift for a 2door. If you don't have adj ca's, you will need a set. I would also suggest that you go with yokes on the new driveshaft, not the stock flanges. (if you go with another stock ds, this will just keep repeating.)
Old Feb 23, 2011 | 01:38 PM
Schwheelz's Avatar
Originally Posted by nthinuf
Obviously.
Im going to convert to a u joint driveshaft for sure
Old Feb 23, 2011 | 01:39 PM
Schwheelz's Avatar
Not yet, but they are on the list.. I was hoping the driveshaft would hold for a couple months
Old Feb 23, 2011 | 03:04 PM
GREENJEEP80's Avatar
That axle is on the way out.
Old Feb 23, 2011 | 03:06 PM
I presume you meant driveshaft?
Old Feb 23, 2011 | 03:07 PM
Schwheelz's Avatar
Axle?! Huh!
