Sponsored by:
Sponsored by: DashLynx
Idle issues when downshifting or coming to a stop but doesn't die
Old 10-17-2016, 10:37 AM
taetaewee's Avatar
Originally Posted by Ryan0260
If it idles rough, but runs fine otherwise, start by cleaning the throttle body and idle air control valve. If you can't clean the idle air control valve, just replace it. Maybe run some seafoam through the tank as well.
What is seafoam?
Old 10-17-2016, 06:13 PM
Ryan0260's Avatar
It is a fuel system and combustion chamber cleaner. You can get it at any auto parts store.
Old 10-19-2016, 08:18 AM
arecee's Avatar
I had the same problem a few months back, I removed the throttle body which was dirty ahel and cleaned and haven't had the problem since.
Give it a try , its fairly simple to do and might solve your problem.
Old 12-07-2016, 08:39 AM
taetaewee's Avatar
Default Still have the issue after doing some replacements
So I replaced the throttle body, plugs and wires. The issue is actually worse now. The 4x4 place that is local mentioned getting my computer reflashed...but I have a feeling its going to get expensive to do that. Any other things i can do to avoid that? After dropping 200$ on the throttle, I am pretty upset it didn't solve the issue.
Quick Reply: Idle issues when downshifting or coming to a stop but doesn't die
