intank fuel pump
Old Sep 18, 2009 | 03:34 AM
SLeepY_BoY's Avatar
Default intank fuel pump
hi guys im planning on upgrading the fuel system in my jk.. for a future conversion project....... i just want to know if anyone knows how i can reach the stock intank fuel pump? some pics would really help
Old Sep 18, 2009 | 05:08 AM
RedneckJeep's Avatar
I would begin by removing the tank. From there, it should be pretty obvious.
Old Sep 18, 2009 | 06:21 AM
gotta tank the tank down, from there the pump is held in by a big ring that either unscrews or has to be turned a few degrees to clear the hold down tabs.
Old Sep 18, 2009 | 06:35 AM
SLeepY_BoY's Avatar
so i have to remove the tank?, theres no way to get in for the floor of the jeep?
Old Sep 18, 2009 | 06:41 AM
yah, with a drill, sawzall, cutoff tool and a grinder should do.
taking the tank off ain that bad, just make sure its almost empty cause getting the gas out aint that easy, there is a check valve that the hose will probably get stuck in.
Old Sep 18, 2009 | 06:59 AM
That's actually a great question. A lot of Toyotas have an access panel under the carpet for the sending unit and fuel pump. It's a great concept....you know, make a vehicle that's actually EASY to service? Unfortunately, the Jeep doesn't have such brilliant innovation. Tank removal isn't tough though. Just remember, the skid plate bolts actually hold the tank in, too....so be ready for it to fall.
Old Sep 18, 2009 | 07:21 AM
SLeepY_BoY's Avatar
thanks for the heads up, do you have an idea at what psi the stock fuel pump flows?
Old Sep 18, 2009 | 09:39 AM
JeepDawg's Avatar
I have to ask.........what kind of upgrade are you planning?
Old Sep 18, 2009 | 09:43 AM
Notta clue. I would just GUESS 40-60 PSI.....but since I've been out of the loop for a while, it is what it is, only a guess. I would also GUESS that more than likely a pump from some other Jeep (perhaps even with a HEMI) could be a direct drop in replacement. I know with GM all through the eighties and nineties, a lot of that was done.
Old Sep 18, 2009 | 10:30 AM
racinfast002's Avatar
pressure is determined by the fuel pressure unit not the pump
