jk just shut off
Old Feb 8, 2013 | 05:05 PM
rickz's Avatar
Default jk just shut off
driving 07 rubicon today just went into 3rd and the jk just shut off luckly i could pull off road -it started right up didn't hapen again i did a lot of driving since and nothing any idea what it could be 2007 rubicon stick stock with 2 in lift
Old Feb 8, 2013 | 05:32 PM
k0260's Avatar
This happened in my 07 stick one time (knock on wood) too. Luckily at a slow speed, the whole thing just went dead, all electrical, engine, etc. Started back up fine, hasn't happened since, 4 yrs ago. Mine was bone stock at the time....
Old Feb 9, 2013 | 03:53 PM
Woodbutcher's Avatar
Seems there was a recall for some 07 jeeps, maybe you qualify?...good luck
Project-JK.com - Jeep JK Wrangler Resource » Safety Recall G25 Reprogram TIPM
Old Feb 9, 2013 | 06:46 PM
DunnyBunny's Avatar
JK-Forum Ambassador
I had opposite issue today. Wipers came on, horn came on and wouldn't go off, doors locked and wouldn't unlock unless forced. Pulled over turned key off and pulled out and nothing shut off including engine. Put key back in turned it over and everything stopped. Working fine now except check engine light now on.
Old Feb 10, 2013 | 09:50 AM
Ryan0260's Avatar
It would be hard to diagnose unless you can recreate the problem.
Old Feb 10, 2013 | 03:21 PM
aquarices's Avatar
This happened to me and I reseated my battery terminals. Hasn't happened again.
Old Feb 10, 2013 | 04:47 PM
Ryan0260's Avatar
This is the best place to start
Old Feb 13, 2013 | 09:22 PM
duneslider's Avatar
This was a known problem with the 07. If it never went into the dealer for a new flash it needs it. Nothing you do to it will fix the glitch, it has to receive a flash to correct the programming.
Old Feb 13, 2013 | 09:30 PM
Fugg it's Avatar
x2, this happened to me too on the highway. tightened up my terminals and never happened again. did your gauges and stuff flash like it could have been battery related or just off?
Old Feb 14, 2013 | 06:27 AM
Ryan0260's Avatar
Yes. If you haven't taken the time you should run to the dealer and have them check for recalls and do a re-flash. There have been several re-flash updates for 07's that I know of.
