Key Fob - Can I use one from my totaled Jeep on my new one?
I have 2 key fobs that came with my Jeep and one left over from my totaled Jeep. Is there anyway I can program the totaled Jeeps key fob to this Jeep?
I don't know if there any tricks to self program the jeep key fobs. I was just able to do it on my daughters Mitsubishi. For that car I had to ground pin 1 on the obd port then push the hazard button 6 times then push the lock button on the remote 3 times. It worked!
Yes you can program the new key fob. All you need is the 2 keys from the new jeep. There is a thread on here that lists how to do it. You can also get a hollow key fob with a blank key on eBay. Then all you have to do is get the key cut and transfer the guts from your old key into the new one.
https://www.jk-forum.com/forums/jk-w...re-key-119610/.
Update to add link above.
I'm not so sure that you can re-code a transponder key from one JK to work on another JK.
I know you can code a new (cut blank) to match your JK but I have not heard of anyone taking a transponder key that has been previously coded to a JK and changing the code to match a different JK.
I'm not saying it can't be done, I'm just saying I've never read a post of it being done. Anyone know for sure?
Also I am not sure if the Scooby is asking about re-coding the old JK key just to have a matching transponder or if by mentioning the fobs, he want to use the buttons (un/lock, panic, maybe remote start) on the fob. I don't know how or if those can be matched to a new JK but I suspect it would involve the STARscan at the dealer.
They keys have two aspects to them. 1) the SENTRY key transponder, and 2) for power group option JKs, the programmed electronics for door locks, alarm, etc.
If you wanted to get a blank transponder key with an empty electronics-shell and transfer the electronics from the old-JK's key into a new fob (and have it cut to match the new JK) you can code the blank's transponder but, I think you still have the issue of matching the electronics to the new jeep.
