Locked Keys in Jeep? Or lost key? Help!
you can try the tennis ball trick, but it may dent the door.
http://www.youtube.com/watch?v=HhbCxaJBI_g
Installing some speakers ...I locked the Jeep w/ BOTH keys inside...
....I had to fabricate a Jimmy w/ aluminum tray covers..( I should have kept it ...and started a Write-Up on Fabricating a Jimmy..)...after 10 minutes ...I was in....
I went to hardware store to cut another key....for my Wallet....testing the door cylinders....it worked ...but then I tried the Ignition....and the car turned on...Is this Normal..?...I thought the keys had a Chip....
No need to disconnect the battery to keep from triggering the alarm when u open the door. Open hood, open fuse box, pull up (no need to remove) the iod fuse.
https://www.jk-forum.com/forums/show...sage-(Resolved)
Probably addressed five times already - but have a dummy key cut. With electronic keys, it really isn't an issue to have a steel key sitting around the vehicle. I have mine somewhere in the engine compartment. Cost $3 or less, and that is cheap insurance vs a locksmith. Since the engine wont run with it anyway, I don't even know why I have it hidden.
