Sponsored by:
Sponsored by: DashLynx
Low Idle???
Old 04-30-2011, 10:46 AM
Red Stinger's Avatar
Originally Posted by Battlefrog
Have you checked the timing ?
How do I check the timing?
Old 04-30-2011, 10:51 AM
damunoz32's Avatar
Mines an 09
Old 04-30-2011, 11:24 AM
lowe516's Avatar
Mine is also an 09 auto
Old 04-30-2011, 11:50 AM
Battlefrog's Avatar
Timing gun. You should also be able to hit up your local advanced auto or auto zone and they can hook your JK up to the computer for a quick diagnosis.
Old 04-30-2011, 11:55 AM
bostonMA's Avatar
I bet it is your electronic throttle body that is causing the problem. Mine was either replaced or repaired (never know when delaing with the dealer) a while back and this has not happened since. I was a 15k at the time.
Old 04-30-2011, 12:20 PM
klutz1001's Avatar
I'm having the same problem. My dealer diagnosed it with an alternator and one is ordered with install set for Tuesday. I will keep yall updated.
Old 04-30-2011, 04:55 PM
damunoz32's Avatar
Thanks for the input fellas. Guess I'll go by the stealership this week to have them check it out.
Old 04-30-2011, 05:44 PM
cajunaviator's Avatar
My 07 with an auto trans does the same thing. I need to bring it in for the timing cover issue, my water pump is leaking and the fuel tank issue. Glad I have lifetime powertrain warranty.
Old 04-30-2011, 11:09 PM
regularsbygod's Avatar
if ur jeep cranks over, its not the starter. idling low is a fuel problem, start with the simplest solution and get a Fuel Injection cleaner fluid and run it through for the next couple fuelings. if the injector is clogged, dirty or whatever from the water in the fuel, it could be cleared up. if that dosent seem to do the trick, follow up with the fuel filter, and then the fuel pump. hope it helps
Old 05-01-2011, 05:54 AM
This is what I actually planned to do this afternoon. I was thinking that a lot of these gas stations probably carry pretty shitty gas. And I really hope that fixes it, because the dealership here is straight up crooked, not to mention abnormally slow.
Quick Reply: Low Idle???
