Mexican made Engine?
Old Sep 2, 2011 | 02:21 PM
  #61
Ryan0260's Avatar
Originally Posted by mainejeeper
I'd like to know where my engine was made. How can you read the numbers if they are on the drivers side toward the rear of the block just below the intake? The exhaust manifold blocks that from view. I can't see it from under the Jeep because the automatic tranny blocks where it should be. Am I missing something?
Nathan
X2. Wondering this as well....
Old Sep 2, 2011 | 03:49 PM
  #62
ronjenx's Avatar
Nathan
You use a light and a mirror, and look at the back of the block, just below the head.
If you are ever in the Bangor area, let me know, and we'll find the engine number.
Old Sep 2, 2011 | 04:07 PM
  #63
mainejeeper's Avatar
Ronjenx, thanks for the tip and also for the offer! I live down south in Eliot, near Kittery. I've been meaning to tell you that I've really appreciated your coments on this and other topics. You know your stuff and it shows!
Nathan
Old Sep 2, 2011 | 04:13 PM
  #64
tncruiser's Avatar
Originally Posted by ronjenx
I could not find any evidence the Wrangler 3.8L engine is made in Mexico.
This is on my window sticker:
my sticker says 79%
wonder what makes the diff
brianj
Old Sep 2, 2011 | 04:16 PM
  #65
ronjenx's Avatar
Nathan
Thanks for the compliment. I appreciate it.
Let me know if you ever get up this way.
Old Sep 2, 2011 | 04:23 PM
  #66
webejeepin's Avatar
Yes, the mirror and little light does the trick,,,,however, I have looked and looked, and I have is my last 8 VIN digits. My mirror is telecopic and I've been all around the area behind the block were I found the VIN stamp....NO MOTOR CODE.
On a positive note I can find the spot were the stamped the number in seconds
Were else could it be? Did they forget to stamp my motor number?
Like most here I'd really like to know. Wonder if a build sheet would tell me if I could score one.
Old Sep 2, 2011 | 04:30 PM
  #67
ronjenx's Avatar
Did you clean the entire area where you found the VIN on the block?
I had to clean with rag and solvent, several times, before it was readable.
On mine, there was a little separation between the two strings of numbers.
Old Sep 2, 2011 | 04:40 PM
  #68
webejeepin's Avatar
I did clean it with just a wet rag, good call on the solvent...I'm going to give that a try bit a break cleaner on a rag should do, maybe the stamp is full dirt.
Also, see if there's a seperation.
Is it possible they didn't stamp this part? I'll let you know if I find it, thanks once again.
Old Sep 2, 2011 | 04:51 PM
  #69
yayomtz's Avatar
A huevoooo hecho en México cabrones! Jejejejejeej just joke! Lol
