Mirror water leak fixed without a drill?
Here's what I did.
Remove the bolt with a T40 Torx wrench.
With the palm of my hand, I hit the bottom of the mirror (under the actual mirror part), in order to break the mirror assembly loose.
Then with a good solid grip, I pulled the mirror bracket cover off (part that gets drilled).
I cut the foam out.
I enlarged the existing factory drain hole to about 3/16" diameter. You can see the enlarged drain hole, in the pic.
Pic:
I cut the foam out.
Pic:
