Mirror water leak fixed without a drill?
Old May 11, 2007 | 01:09 PM
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Here's what I did.
Remove the bolt with a T40 Torx wrench.
With the palm of my hand, I hit the bottom of the mirror (under the actual mirror part), in order to break the mirror assembly loose.
Then with a good solid grip, I pulled the mirror bracket cover off (part that gets drilled).
I cut the foam out.
I enlarged the existing factory drain hole to about 3/16" diameter. You can see the enlarged drain hole, in the pic.
Pic:
Old May 11, 2007 | 01:42 PM
mshea's Avatar
I just took the doors off. problem solved.
Old May 12, 2007 | 02:39 PM
mlbplayer86's Avatar
i just used a fine tip screw driver and pushed and twisted it into the plastic until it went through. Water poured out
