Mopar half doors & factory hard top
#21
I'm not a big fan of the way those previous pictures look with the Black 2 door JK. I think it looks best when the top is off and the 1/2 doors are mounted without the uppers.
#22
bestop is not making the top sliders for the jk and rampage has them under devolopment .was set to be released last holiday but put off due to fitment issues my order has been in almost a year. dont hold your breath
#24
Half doors with Hard top
Hi all, I'm form South Africa and most Rubicons that we get here, come with the half doors. They work 100% with the factory hard top and seals well. a Little bit of wind noise never bothered any Jeep Wrangler owner.
I drive my JK most of the time without the uppers, only when the family or weather demands it I fir then uppers, but we here in Africa have great weather for 11 months of the year !
#26
#27
i don't see a big enough difference on the jk. the half doors are like the full ones with the window frame cut off. tj and yj half doors are almost 1/3rd doors. has alot to do with the body style. not much you can do as it has to match up with the tub in the back and tj and yj's had lower tubs. must say i really like the tube doors.
#28
I don't think the half doors are available with a hard top from the factory. Not that it matters to the OP who is interested in aftermarket doors.
#29
#30
The JK is the same as the TJ and YJ. The top of the half doors are exactly even with the top of the body tub in the back. They are MUCH shorter than the full doors with the frames cut off. The reason they are bigger top to bottom than the TJ and YJ is because the door on the JK goes all the way to the floor whereas the TJ and YJ bodies are actual tubs and have a huge lip you need to step over to get out. I don't think the JK tub is much taller.
