New Jeep w/ leak
hey guys, i just got a new 09 sahara w/ the freedom top. This seems to be a touchy subject here buuuuut.... The top is leaking in through the passenger side sound bar bolt.
I did a search on here and was horrified by all the leak complaints. Wow, not cool. Everything i can find on here seems to be older posts regarding leaking around the windshield etc.
It seems like mine is leaking in a different manner than most others. First of all, water is obviously getting in somewhere, but it hasn't rained in a couple days and I am still getting water through the bolt. Obviously, there is some water trapped up there, when I take a left hand turn, it leaks in on my wife (not impressed).
I did remove the freedom tops and look at the seals, they don't "appear" damaged?
I am on the way to my dealership to let them know what is happening..
What recourse do i have to get this dealt with and not have to go through the horror that many others on here have?
Thank You
Thank You
Try giving the seals a light coat of vasilene or wipe them down with some 303 or something to make them seal a bit better. Mine dripped a little ONE time back when I first got it. After I started greasing it , no problems since.
Thank You
Thank You
thanks, the weather is horrible here today.
I will check the passenger side top when the weather permits. What was the solution? did the dealer replace the passenger side top?
Also, I like the idea of a little grease.
Salt man, is it REALLY that bad? why so disenchanted?
This is a video of my replacement for my last JK that was bought back by Chrysler for leaking and various electrical problems. It has less than 5 thousand miles on it. This is three days after getting it back from having the door sills replaced. Sorry the video kind of sucks but you will get the point. All four doors do this. As you will see/hear this is a light rain. It's MUCH worse when it really rains. This Jeep actually leaks through the header at the front and drips in the center near the rear view with a soft top also. Excellent!
http://www.youtube.com/watch?v=bKOYRETxwNE
theres a tsb report or somethin like that.they have in there computer's cause i have to get it done to my jeep. but its like 27 pages long and they will have to have your jeep for a few day's, if its under warrenty id get it done if it bothers u that much cause it would come out to a lil over a grand to have it done out of warrenty thats what i was told at the dealership.
Thank You
Thank You
Chris.
