New Superchips Transmission Temp Feature.
Yes its there on mine. First I had the NGC3 selected & the readout was blank. I switched mine program back to stock, reloaded the 87 tune that I run, then found the second trans temp option under the NGC4 selection. It worked. You did have the hot oil update done also right? If so it should work.
I had my SC plugged in all day looking at how hot my trans would get. It never even broke 147 degrees all day. My B&M trans cooler seems to be doing its job!
I had an issue getting the Trans temp feature to work on my VIVID.
I had called Superchips and after the trans update, they were able to do something, that once I updated the tuner module it worked, i can monitor the trans temp with no issue now. If any else has the same problem, I'd suggest giving superchips a call. If it worked for me, it might work for someone else.
