Oil Leak
Oddest thing, was making up a few new connectors. Driver side ignition coils have 18 gauge wires to the harness and the passenger have 16 gauge (I was wrong - measured with a caliper, it is 16 but thinner sheathing). Looked at the connector diagrams and all state 16.
Another thing I learned is if you need replacement connectors look them up here http://connectors.dcctools.com/ and is seem the image filename is the manufacturer part number. For example the ignition coil is 1-1924067-1.gif.
https://www.newark.com/amp-te-connec...d&exaMfpn=true
They are a $1.50 USD each and the pins and seals are about another $1.00. MOPAR is $50.00.
Wonder if cold weather can be a factor? You are in Newmarket and I’m just a bit south of you.
I have 220,000 km on my 2013 JKU and the filter housing started leaking. We also had the really cold snap. I could smell burning oil, put it on the hoist and had oil exactly where you had it.
We replaced the housing and the seals. Only other thing I should look into is the extended warranty on the passenger side heads.
it’s like these things had a self destruct in them to all go at the same time. Where did you manage to find a housing from? No way was I going to pay inflated dealer price.
I think part was was around $260. A buddy owns a shop in Markham and did the install. I have 230,000 on mine so figure it was due. We took off a lot of parts to get to it so considering the shop labour it made sense to do everything. Plus mine had a crack in the tube. These are common for failure. Also corrosion from that brine crap we put on our roads.
