Oil sucking 3.8
#51
The engine is still hot so i could not wipe much with out burning myself. I think your right it does not seem like a leak. I was able to wipe some off. The number is on the block part which is darker than the head right? The numbers seem small (if I am looking at the correct ones). Over the weekend once the engine cools down I will get my hand back there and clean it up and take another look.
Next week im changing the pcv valve and the oil to a thicker weight 10W-30. The dealer said that using 10W-30 is ok with them and will not void the warranty. (I did not tell them my name or give them my vin) just in case they wanted to flash something on the vin. I dealt with them in the past for my liberty and they are strait up guys. I an not naive though and am keeping my records what are inline with a warranty claim.
#52
I hope I am looking at the correct set of numbers I saw a set of numbers about 8 numbers long. They seem to be engraved in the block.
#53
I dont understand since it should be either an S or a T and i have an L. It matches the last 8 of my vin. I have found that the L means it was assembled in Toledo. So does that mean I have an american engine?
Am I doing something wrong? I must be looking in the wrong place
#54
I am now confused. The second character is an L. The only things I can see back there are first on the silver head on a circular area it Is a raised 823A. Then directly below that where the block and head meet the block has an engraving or stamp of 8L568326.
I'll report back in when I check again.
ALso, I staarted the offical oil consumption test with my dealer...they changed the oil AND PCV filter, I've since put on just over 1,200 KMS, and oil level seems to be holding. I will assume they filled the crank case with 5W20. We'll see and post results as we go.
#55
Mine is to the left, and below the VIN.
#56
3.8 Oil Consumption
I have a 2008 JK Wrangler with 55000 miles on it. I noticed a few months back that I was losing a considerable amount of oil or at least far more than I had ever lost on any previous vehicles I have had, many with far more miles on them. I was having some hinge rust issues taken care of at my dealership and also mentioned what I thought to be unusually high oil consumption. Within 10 minutes of me vehicle being checked in the service manager informed me that this was common for this engine and they would replace all of the piston rings. Having seen some of the previous posts I felt lucky I did not have to push the matter. They seemed pretty familiar with the issue.... we'll see! There were some less than complimentary comments regarding this engine!!!!!
#57
#58
#59
Originally Posted by iagainsti
They replaced your rings just like that ? No consumption test ? Wow you have a good dealer. My engine sounds like its grinding metal and the dealer and factory have been fighting for over a month on what to do about it. The dealer says it needs a rebuild and the factory is refusing to allow the warranty.
#60
Thats bullshit! They build a crap motor and don't want to stand behind it. I have a feeling that with more of these cases popping up everyday that they will end up with a huge lawsuit if they don't start making it right. A properly built engine shouldn't consume much oil and ping like these things do. The 3.8 sucks imo
