P06DD Code on 3.6
Old Mar 23, 2021 | 05:57 AM
  #31
joekadzban's Avatar
Originally Posted by Micheal Batchelor
Got this code yesterday already had oil cooler housing and sensor replaced a couple of months ago so almost definitely the oil pump found just the solenoid on rock auto should I replace the whole pump or try just the solenoid any advice appreciated.
It is a lot of work to get to the solenoid, which is attached to the pump. I suggest the pump and solenoid.
Old Jul 23, 2021 | 07:46 AM
  #32
AlecJK's Avatar
Originally Posted by JYoungblood
2015 Wrangler Unlimited Sport.
Jeep shop replaced the Oil cooler and sensor. Still got P06DD. Then we replaced the oil pump still got P06DD. Used all mopar parts. Oil pressure is sitting around 10psi when warmed up.
Thoughts? What do we do next? TIA.
This is the same situation I am in right now. Did you find a solution? Any help would be greatly appreciated!
Old Dec 11, 2021 | 08:26 PM
  #33
NoahsJK's Avatar
any luck?
+1 here, 2013 JKU 3.6L, new Mopar oil cooler housing/ pressure sensor/ oil filter/ oil pump assembly/ oil pressure solenoid. All mopar parts, running Penzoil ultra platinum 5w20. All wiring to oil pump solenoid tests good, wiring to oil pressure sensor tests good. Oil pressure at idle drops as low as 9 psi, raises with engine speed as it is supposed to. Whats strange is that it will set P06dd when cold (engine oil temp below about 200*F) and then if I clear code and keep driving it will stay off until engine sits long enough for oil temp to drop down. I am stumpped on this, trying to figure out if I need to throw an ECU at it or just put a reman long block in to get this damn code to quit.
Old Jan 4, 2022 | 12:45 AM
  #34
Mrfixitall's Avatar
Originally Posted by NoahsJK
any luck?
Try replacing the pressure relief valve. They have a TSB about it, im sure its your issue especially if you have replaced the pump. Im dealing with the same code, have not change neither of them and I think I'm going try the cheap route first. Another oil change and the pressure relief valve.
Old Jan 4, 2022 | 03:39 AM
  #35
NoahsJK's Avatar
My first "fix" was the pressure relief valve $14.95 Dorman part, that made no difference.
What ended up being the fix for me after replacing everything was swapping oil cooler assembly for the revised 2014+ aluminum housing Dorman makes. Several hundred miles on since the replacement and NO CEL.
Old Jan 12, 2022 | 09:20 AM
  #36
thenomad's Avatar
Whe. I got that dope I replaced oil pump and no more issues. Easy to do
Old Jul 4, 2022 | 08:02 PM
  #37
jprodriguez's Avatar
Default Same Issue on Dodge Journey
any luck?
I have a 2012 Dodge Journey SXT 3.6L pentastar engine and I'm having the exact same issue, did you solve it?
Old Sep 3, 2022 | 10:37 AM
  #38
RockRsh's Avatar
any luck?
Its the oil galley bolts on the front of each head under the timing cover. If there loose the let air into the system.
Old Nov 6, 2022 | 01:37 PM
  #39
dwx's Avatar
dwx
I've had this code at various times over the last two years now. I do think part of it has to do with the oil and filter being used. When I use a decent filter vs. not it does seem to trigger the issue less often. However that hasn't completely eliminated the issue. At times the codes have disappeared long enough to get the car emissions tested but now I have a new electrical related code P1628 and am looking harder at fixing the P06DD. Changing the oil pump and solenoid seems somewhat straightforward but also a PITA. Has anyone had any luck changing just the solenoid?
Old Dec 17, 2023 | 05:14 PM
  #40
NeedMore$'s Avatar
I just got the same P06DD code and searched internet for solution. Saw one guy on youtube replaced just the solenoid on the oil pump, and that cleared the problem. I did replace my Oil Cooler a few thousand miles ago with OEM cooler with new sensors, so hopefully it is not them. Is a PITA, since I have an E-Force supercharger that also has to be removed to access the cooler.
he got part from Dorman on Amazon (Dorman 926-235 Variable Oil Pump Solenoid Compatible with Select Models (OE FIX)). https://amzn.to/3WWql3e
I am curious if there can be any damage to engine due to this code?
