Pisses off Jeep owner
Old Oct 30, 2010 | 04:36 PM
Scastlet's Avatar
I have a 2010 Jeep Wrangler Unlimited Islander and I love it but... When I go off-roading with it the front fender flares always come loose and the front air dam almost got ripped off. And the engine sucks in water very easily because of where the air intake is and I almost hydro locked it twice I a mud little that a old jeep wrangler can get through with no problems. Why did Chrysler go so cheap on the new jeeps. It's pissing me off.
Edit: The fender flares were not ripped off some of the clips for the fender flare came loose.
Old Oct 30, 2010 | 05:17 PM
captjay's Avatar
fender flares: check to make sure the clips are running length wise, not up and down and if you have rubbed or hit something in the past, u probably knocked it loose and has not been tight ever since. there are way to many clips on the flares for it to just come loose
air damn: "front air dam almost got ripped off". stop hitting stuff, stop going through deep mud and water, not the best for offroad anyways
water: stop going through water and mud fast or too deep of water, if you take it nice and slow, you should have zero issues of sucking in water unless you are in water as deep as you hood
Old Oct 30, 2010 | 06:14 PM
glocksrfun's Avatar
It's chrysler, 'nuf said
Old Oct 31, 2010 | 02:40 AM
RubiRush's Avatar
From the sounds of it you beat on your Jeep pretty hard. They are Jeeps not tanks, if your going to play hard be prepared to work on it to keep it running.
If you're hitting a mud hole hard enough to nearly hydro-lock your engine maybe the hole is too much for your setup or you should adjust your driving style when off roading.
Old Oct 31, 2010 | 06:48 AM
Bad_CRC's Avatar
if it's a problem just get a snorkel and aftermarket fenders.
sounds like you aren't one to take very good care of your ride, so you need some mods, the jeep is pretty darn capable stock, but at serious extremes, you need some changes.
Old Oct 31, 2010 | 07:24 AM
benny's Avatar
[QUOTE=Scastlet;1916615] I almost hydro locked it twice I a mud little that a old jeep wrangler can get through with no problems.
Ummmm,.........what?
Just kidding, I know what you mean.
Old Oct 31, 2010 | 07:42 AM
Scastlet's Avatar
The puddle was a small mud puddle barely up my tire and I was going 10mph through it and when I got out of it I let up on the gas and it shut off ad the air box was filled with muddy water. And I am very careful with my jeep. I've seen people go 30+ in that mud and I went 10 and this problem happened to me.
Old Nov 30, 2010 | 10:18 PM
bingote's Avatar
How do i know how deep can i go into water?
lets say i wanto to cross a river or something... if water is above "_______" or below "______" just don't go... any ideas?
Old Nov 30, 2010 | 10:40 PM
nthinuf's Avatar
Try reading your manual...
CAUTION!
When driving through water, do not exceed 5 mph (8
km/h). Always check water depth before entering as
a precaution, and check all fluids afterward. Driving
through water may cause damage that may not be
covered by the new vehicle limited warranty.
Old Nov 30, 2010 | 10:41 PM
nthinuf's Avatar
Again, the manual says...
Flowing Water
If the water is swift flowing and rising (as in storm
run-off) avoid crossing until the water level recedes
and/or the flow rate is reduced. If you must cross
flowing water avoid depths in excess of 9 inches. The
flowing water can erode the streambed causing your
vehicle to sink into deeper water. Determine exit point(s)
that are downstream of your entry point to allow for
drifting.
Standing Water
Avoid driving in standing water deeper than 20 inches,
and reduce speed appropriately to minimize wave effects.
Maximum speed in 20 inches of water is less than 5
mph (8 km/h).
