Quick. Soft top Help.
Just pu the top down with your other hand. Make sure that their is nothing stopping the top from going into place ie other latch, outside of the door trim, twisted straps( back half of the top). Make sure that it's installed correctly, and install the top in the correct order.
undo the back flaps, lean them forward, then make sure those clips are fully open, put the front on then to the back again, I had/have the same problem top is still new once it streches some you should be good
TIP:: After you have the header hooks locked down check the outside where the windshield and top come together. If you see some of the rubber seal from the windshield sort of bumping up, then push it down with your finger. If you don't you will hear a whistle at about 30 mph.
Good Luck
Originally Posted by augichef
Agree undo the rear flaps and then rehook
Good luck
Augi
The most common problem I think is the rear pieces called the sail flaps
Flip those up and out of the way
Bring the whole top up and into place, see if the main clamps are close enough to hook onto the windshield
There are many videos on YouTube that go through it step by step...
Even after doing it probably 100 times sometimes it just doesn't want to just go up
Other then the bad headlights, the soft top comes in a close second for things that could use improvement...
If its your first time it helps if it's warm out
Matthew
Matthew
And yell, lots of yelling for that first time.
