Quick. Soft top Help.
Old May 17, 2012 | 10:41 AM
NJBlackBetty's Avatar
Default Quick. Soft top Help.
Can't get it to close. First time putting it on.
Old May 17, 2012 | 10:47 AM
pirate's Avatar
Just pu the top down with your other hand. Make sure that their is nothing stopping the top from going into place ie other latch, outside of the door trim, twisted straps( back half of the top). Make sure that it's installed correctly, and install the top in the correct order.
Old May 17, 2012 | 10:59 AM
afpilot82's Avatar
JK-Forum Ambassador
C'mon, put some muscle into it!
Old May 17, 2012 | 11:11 AM
damunoz32's Avatar
I usually close the latches half way before attaching the flaps in the back. After back flaps are in, close latches all the way. Never fails me.
Old May 17, 2012 | 12:05 PM
Pete1971's Avatar
undo the back flaps, lean them forward, then make sure those clips are fully open, put the front on then to the back again, I had/have the same problem top is still new once it streches some you should be good
Old May 17, 2012 | 04:17 PM
augichef's Avatar
Agree undo the rear flaps and then rehook
Old May 17, 2012 | 04:20 PM
Rooster76's Avatar
X2 Make sure that the clips are fully open that is what got me. That pushes the hook out some. Once you have them just hooked don't tighten them down until you have the back flaps attached.
TIP:: After you have the header hooks locked down check the outside where the windshield and top come together. If you see some of the rubber seal from the windshield sort of bumping up, then push it down with your finger. If you don't you will hear a whistle at about 30 mph.
Good Luck
Old May 17, 2012 | 04:23 PM
augichef's Avatar
I had the same issue when I installed my top the first time. Like I said undo the flaps then make sure you pull the header handles all the way back so that the hooks move all the way forward so you can reach. Next redo the rear flaps then close the header handles.
Good luck
Augi
Old May 17, 2012 | 04:25 PM
Matthewd5's Avatar
The most common problem I think is the rear pieces called the sail flaps
Flip those up and out of the way
Bring the whole top up and into place, see if the main clamps are close enough to hook onto the windshield
There are many videos on YouTube that go through it step by step...
Even after doing it probably 100 times sometimes it just doesn't want to just go up
Other then the bad headlights, the soft top comes in a close second for things that could use improvement...
If its your first time it helps if it's warm out
Matthew
Old May 17, 2012 | 04:32 PM
Rule18's Avatar
And yell, lots of yelling for that first time.
First time I swap tops every year, I get the soft top stretched out for a while but not latched. The sun is our friend!
