Rattle
Old Jul 19, 2010 | 07:36 AM
TN_JK_GA's Avatar
Default Rattle
I have a 4dr soft top Wrangler. I have a rattle that sometimes sounds like it behind my head and other times it sounds like is coming from above the back seat. It just start Sunday. Anyone have a a list of common problems and solutions this might be. It is hard to pin down. I have tried tapping different sections. The threat ran has been pretty good so I have not let the top down but it has been on for a week. So I am not sure why it just started.
Thanks
Old Jul 19, 2010 | 07:40 AM
db09JKU's Avatar
Sound like it is behind your head around where the seat belt attaches to the B pillar?
Put electrical tape around your door striker, bet it works. I know it sounds crazy, but it works. People have tried grease, readjusting, etc, and the noise comes back. Tape is cheap, and easy and works for extended periods of time.
Do a search for noises in that area and you will find threads on noises that I just described. Mine did it within 2 weeks of getting it, I put the electrical tape on the striker, and fixed it immediately. I have replaced the tape twice, still no noises.
If this is not the case, at least you knocked that known problem out of the list of things to check.
Old Jul 19, 2010 | 11:30 AM
TN_JK_GA's Avatar
Default Shot
I will five it a shot tonight.
Old Jul 19, 2010 | 04:25 PM
jeepmedic's Avatar
I had the same rattle. I just took the plastic all apart above the pass seat on the B post, removed the foam, and just put it all together and the noise went away....
Old Jul 19, 2010 | 05:17 PM
doubleusn's Avatar
Not sure if it's the same, but I had a rattle/squeak, that was making me crazy.
I had the misses ride behind me and she said it was coming from where the soft top attached to the roll-bar in the rear.
I just re-tightened the 4 torx bolts on each side, and it appears to have gone away.
Good luck...
Old Jul 19, 2010 | 05:30 PM
MM Jeep's Avatar
Interestin! I thightened my strikers and latches and it seemed to go away, Ill try the tape if it reappears.
Old Dec 11, 2010 | 11:29 AM
jeepguy21's Avatar
Ive been searching for a fix for my rattle too, found when the radio is on my dome light rattles if you turn it up to loud, not distorted loud though.
Old Dec 13, 2010 | 07:05 PM
b4tn's Avatar
This has been driving me nuts for weeks!! What's a door Stryker? Sounds like it is right around the seatbelt mount. It's more of a clunk than a rattle though.
Old Dec 13, 2010 | 07:19 PM
doubleusn's Avatar
FWIW: I have found the hard styro under the roll-bar cover behind my head rattles against the bar. Not sure if it is because it is cold, so it is now less pliable. I used a piece of the stuff that ships on laptop screen (padding) to put between them
... Rattle all gone now :-)
Old Dec 16, 2010 | 06:07 AM
TN_JK_GA's Avatar
Default Found part of mine
It is the little metal tab or stopper on the soft top right above the door.
It only happens on the driver's side. I put a piece of foam camper tape on it and it worked until I forgot and opened the top.
I am looking into something better or should I bring it up to the dealership and have them fix it?
