Resetting the Check Engine light
Check engine light still on
I know this thread is old, but seems like the best place.
Mine was throwing a P0128 code. I changed the thermostat and housing. Drove it. Still throwing the same code. I did the 3 gas pedal trick. Check engine light still on, but when I check the code I just get - - - done--- Wonder if the sensor is bad (temperature). Or if the light will clear after a few more trips?
Weird.
Jason
Weird.
Jason
Weird.
Jason
Weird.
Jason
I hope you score well and are accepted based on your "admissions" test results
How did you get rid of the P0128 code after replacing the thermostat housing. I replaced my thermostat housing and did a coolant flush and my check engine light is still on.
