Rough Idle
Is it a constant rough idle? Is it never normal?Is it always rough? shaking?
I would think if it was something computer related (or at least something the computer reads) it would shoot you a code.
That's why I threw the motor mount thing in there. How are your RPMS, up and down or constant?
I'm sure in the long run someone here will have a clue as to what it is you are experiencing and you will be on your way to getting it fixed.
I know you probably don't have water in anything but it had similar symptoms just greatly amplified. I wonder if that sensor and or plug could be the problem. I assume it is some kind of air flow sensor. Maybe it needs to be cleaned or the contacts in the connector need to be cleaned. It might be worth a try.
I am not a mechanic but I would just use electrical contact cleaner from an auto parts store on the connector but as for the sensor I am not sure. You have to be careful not to damage them they can be very sensitive.
When the truck I had before my JK was running a rough I cleaned the Mass Air Flow Sensor with some electrical contact cleaner and it took care of the problem. I don't know if that will hurt this sensor or not.
Anyone else know how to clean this sensor?
I went on a trail run with a guy not that long ago who took a water crossing way too fast and his jeep started running really erratically. It would be fine then it would stall then it would idle rough so we limped it to the trail head. At the trail head while we were airing back up we decided to take one last look under the hood and near the intake there is a wire harness going to a sensor in the air tube just before the throttle body. We took that connector off and blew it out and then it ran normal.
Don't just check the connectors check the sensor too. It could be dirty if you do a lot of wheeling. Some of that dust eventually gets around the best of the air filters.
its spotless i clean out my filter every time i change my oil and check the sensor and the intake toob
I just thought all Jeeps did that. I had an 04 that did it and now have an 08 and it does it sometimes as well. That's actually part of the reason I traded in my 04, the dealership told me, "Yes, it idles rough but only when you first start it and we can't figure out why. Sorry, you'll just have to come get it." So I traded for my 08.
