Rumble strip feeling upon acceleration.
Old Nov 1, 2010 | 01:37 PM
davelong667's Avatar
Default Rumble strip feeling upon acceleration.
I get a rumble strip vibration intermittantly at all speeds, regardless of gear, or o/d on or off. I think ive narrowed it down to a couple things. Ive read alot of threads on this issue and think i might have it, but wanted to see what you guys thought first. I have 2 pics.
First pic shows the lift spacer on the front axle, its a rc 2.5 b.b., the front being dang near a 3" spacer to level the jeep out.
It is my belief that this lift has caused my cv joint on my front driveshaft to reach its limit on angle. I notice that the vibration also comes and goes as the body sinks and rises with road features.
Here is a shot of my front drive shaft, near the transfer case, at rest, just sitting.
So my conclusion, is that its either this,or a bad torque converter. If it is my drive shaft. What are my options? Thanks guys
Old Nov 1, 2010 | 01:47 PM
racer83l's Avatar
pull the driveshaft, go for a ride..
Old Nov 1, 2010 | 01:52 PM
Good idea. I think i will tommorow evening. I wont have time tonight. But i will tommorow. I pray that it isnt a torque converter.
Old Nov 1, 2010 | 01:58 PM
racer83l's Avatar
my DS has some vibration issues (its a Tom Woods 1310, he has it right now and is re-working it for me)
I had vibrations at various speeds.. pulled it, they disappeared instantly.. I have been driving for about 2 months without it. It works, but it feels weird driving a lifted JK that is essentially 2wd..
Old Nov 1, 2010 | 02:12 PM
I will know for sure tommorow, but i am thinking it is the front shaft.
Old Nov 1, 2010 | 04:49 PM
deconstructionist's Avatar
tagging to see if the shaft is the problem: there's some more ideas out there if it aint the culprit.
Old Nov 1, 2010 | 04:55 PM
kris003's Avatar
i just got that same lift kit today... now i dont know if i want to install it... what do you think? did you install that kit your self?
Old Nov 1, 2010 | 05:04 PM
Yep, i installed it myself. Not too difficult really. I hope that it IS my drive shaft, that can be fixed without major work. We will findout tommorow.
Old Nov 1, 2010 | 06:55 PM
kris003's Avatar
how many miles and road conditions have you go with that before it started giving you problems? thanks keep me posted (knowledge is power) hehe
Old Nov 2, 2010 | 06:05 AM
jkman77's Avatar
Originally Posted by racer83l
my ds has some vibration issues (its a tom woods 1310, he has it right now and is re-working it for me)
i had vibrations at various speeds.. Pulled it, they disappeared instantly.. I have been driving for about 2 months without it. It works, but it feels weird driving a lifted jk that is essentially 2wd..
most likely your drive shaft was fine. With 5.13 gears your ds will have a very high rpm rate and your pinion angle needs to be just right.
