Spare rattles on a new JK?
Old Apr 29, 2011 | 06:00 PM
speed2005's Avatar
Default Spare rattles on a new JK?
My 2011 JKU Sahara just hit 2,000 miles and for about a week now there’s something bouncing on the very far back. I am thinking it’s the tailgate or the spare. Any ideas? Very annoying every time I go over a bump or a dip in the road.
Old Apr 29, 2011 | 06:11 PM
banx's Avatar
Check your jack. I had the same, turns out the jack was loose and not extended in it's storage space causing an annoying rattle.
Old Apr 29, 2011 | 06:19 PM
Deere_Jeep's Avatar
yep. storage area too
Old Apr 30, 2011 | 02:02 AM
TyRant671's Avatar
I've got an '11 and Im having the same problem. It's been driving me nuts! I believe its actually the storage tray that gets loose, not the spare. I've done several things so far and lining the underneath of the tray with foam works best.
Old May 2, 2011 | 01:40 PM
jstin120's Avatar
Have a 2011 with 1,500 miles. Same problem, but might be the bolts for the doors rattling around back there.
Old May 2, 2011 | 05:59 PM
Friday2322's Avatar
Post
My 2010 did the same thing and I finally figured out it was the spare tire carrier. It was broken and had a large crack along the top that allowed the tire to move around and make that clunking noise when I went over bumps. I was hoping it could be welded back together but it's made out of some kind of pot metal that's not the best to weld. I have no idea how it happended but a replacement carrier was in the $50 range on eBay.
Old May 2, 2011 | 06:03 PM
speed2005's Avatar
thanks guys i think it sounds like it's coming from the outside. Drives me nuts but still could not figure it out. I might have someone drive while i sit beck there to hear exactly where it's coming from!
Old Jun 11, 2011 | 06:05 PM
speed2005's Avatar
forgot to update this.
I took it in and they were able to fix it...no more rattles
Old Jun 12, 2011 | 12:49 AM
NEWWRANGLEROLDCJ7's Avatar
Originally Posted by jeepmojo
checked tailgate door , slight play between latch mechenoisim!! not the top latch but lower alignment brackets , i put a strip of gorilla duct tape just to fill in the amount of play! solved issueAttachment 156735 hope photo helps someone else thats tracking down noises
I am having same clunking noise in my 2011
so I guess it caused by this same thing, hard to see in picture, where did you tape??
Old Jun 12, 2011 | 12:13 PM
GeorgesJeep's Avatar
Same noise in my 2011 6,000miles. I've learned to live with it as long as it's not causing any safety/mechanical issues.
