Stripped Differential Drain Plug
Personally I would get that plug back in however you can and have it welded up tight then get an arb diff cover for your draining. If you can repair the threads you still may end up with a slight leak in a tough spot. Threads are never your friend lol
You could also pull the axle shafts out and drive the Jeep in 2WD (rear axle). This will let you get it to a machinist, if you prefer a pro to work on it (if you have no experience with this kind of work, I'd recommend it). It will also give you experience at pulling the shafts, which is good knowledge for the trail.
Agreed, pulling the axles won't keep the R&P from turning, do both to keep unoiled parts from moving. In the rear at least, in the front axles should be enough
