Thump under JK
Old 01-18-2012, 03:14 PM
raginbull's Avatar
Default Thump under JK
Fellow Jeepers, I need some help. I have 29k on 2010 JKU. The other I noticed that when I back out and then put into Drive and start moving forward I get a loud thump. Can anyone chime in if you have an idea or know? I do my own maintenance but this has me mind boggled. Thanks in advance.
Old 01-18-2012, 03:17 PM
TURTLECON's Avatar
I get the same sound when I go from reverse into forward. I'm pretty sure it's just the tranny engaging. When was the last time you changed the fluid or had it checked out?
Old 01-18-2012, 03:18 PM
raginbull's Avatar
That's exactly when I hear it. I'm doing that this weekend.
Old 01-19-2012, 04:10 AM
raginbull's Avatar
Anyone else want help out a fellow jeeper
Old 01-19-2012, 04:32 AM
warvuk's Avatar
Maybe it's the driveshaft u joint. Is your Jeep lifted with larger tires?
Old 01-19-2012, 08:43 AM
TURTLECON's Avatar
Mine has 3" lift & 35" tires.
Old 01-19-2012, 01:41 PM
raginbull's Avatar
Stock 4x4. Hasn't been lifted?
Old 01-20-2012, 09:12 AM
TURTLECON's Avatar
It's your Jeep. You don't know if it's lifted?
Old 01-20-2012, 10:16 AM
yo_marc's Avatar
Do you use your e-brake when you park?
I used to get a loud 'snap' or pop from the rear of the JK when I'd first start to move forward, after backing up. The e-brake mechanism was binding in the drum. WD40 took care of that.
There are a lot of other things it could be...
Old 01-20-2012, 10:22 AM
AirDWN's Avatar
It's definitely a normal function. My 07' Sahara did the same thing right off the showroom floor. When I shift into Drive or Reverse and move, a big KER-CLUNK sound would occur. However, my 12' JKU WHISTLES instead of KER-CLUNKs.
Quick Reply: Thump under JK
