Sponsored by:
Sponsored by: DashLynx
Time (not mileage) intervals between engine oil change
Old 11-19-2011, 04:18 PM
armor's Avatar
Default Time (not mileage) intervals between engine oil change
Hi,
I accumulate quite a low mileage on my Jeep (2011 Rubi) as my commute to work is very short (lucky ). So I am not reaching recommended mileage for oil changes (be it 3K or 4K miles) even within 6 months. Should I wait to reach the recommended mileage or go ahead and change every 6 months? Or maybe less than 6 months ?
thanks!
Old 11-19-2011, 04:28 PM
kik
kik's Avatar
Originally Posted by armor
Hi,
thanks!
Chrysler wants it done at least every 6 months regardless of the mileage. It's ultimately your call.
duneslider's Avatar
I have always been told 6 months. That's what I do on my truck. It only sees about 6-7k a year.
Old 11-19-2011, 04:31 PM
ronjenx's Avatar
Your short trips are hard on the oil, and engine.
Change it at 6 month intervals so you start out with fresh oil each cold and warm season.
Old 11-19-2011, 04:36 PM
knight1000's Avatar
Im in the same boat. I change in spring and again in fall. I have always done that even when I put more miles on then I do now. Now I work from home and do 50ish miles a week with shopping and stuff.
Old 11-20-2011, 04:24 AM
CaptDuck's Avatar
I change it every 6 months regardless of mileage. My wife has a short commute of 3 miles and she drives the jeep.
Old 11-20-2011, 04:38 AM
Noxian's Avatar
Yup 6 months, oil continues to breakdown from the contaminants even when the engine is not running.
Old 11-20-2011, 05:56 AM
walc's Avatar
The oil change interval on the JK is set for 8,000 miles or 6 months, whichever comes first.
Old 11-20-2011, 06:59 AM
Jiblet's Avatar
I agree with Ron. Since you live in SoCal the 6 months is probably OK but the short trips are extremely severe on the oil. You simply don't spend enough time at operating temperature to boil off the condensation and blow-by fuel etc. If you can, a nice 30 plus minute drive once a week would be a good idea. Repeated short trips are killer on the oil. For anyone in a climate that actually has a cold winter that has repeated short trip duty cycles, I would change even more frequently. Three maybe four times per year.
Does your OCI warn you to change oil?
Not true, there is no setting either miles or time-wise. There is a complicated proprietary algorithm that computes multiple parameters discussed in other threads. The 8,000 miles (6,000 in older models) and 6-month periods are the extreme end of the drain interval range allowed for warranty purposes.
The manufacturer recommends following the OCI but never to exceed the mile/time period.
Old 11-20-2011, 12:42 PM
walc's Avatar
You are absolutely correct.
Sorry, I posted misinformation.
In any event, the JK's have an oil change indicator warning/reminder light, which is based upon the algorithim.
Quick Reply: Time (not mileage) intervals between engine oil change
