Sponsored by:
Sponsored by: DashLynx
Tire size question
Old 08-22-2013, 08:46 AM
marcusjames2's Avatar
Default Tire size question
I have a stock JK Sahara with 4.10 gears and stock Duelers on 18" rims.
Does anyone know how going to Duratrac 275/65/18 or a 33" tire (275/70/18) would effect my gas mileage?
I'm sure it will drop, but trying to figure out how much to see if it would be worth it. I drive in the highway a good bit.
Old 08-22-2013, 08:59 AM
PG-JKU's Avatar
You'll be fine for power but yes the mileage will drop. I went from being able to push around 22 mpg fully stock to 19 mpg if I baby it on the highway. You are lucky to have the 4.10's. I ran 275/65/18 Duratracs for a while and now run 33x12.5x15's. No contest offroad between the duelers and the Duratracs.
Old 08-22-2013, 03:14 PM
Thanks! That is helpful. I'd be willing to take that kind of loss. Maybe mine wouldn't be quite as much with the 4.10 gears.
Old 08-22-2013, 08:40 PM
Matthewd5's Avatar
I'd try the Duratrac's in 285/70/##
I have them in 17" and I am pretty happy with them
On that one change alone I would expect less than 1 mpg loss
Matthew
Sent from my iPad using JK-Forum
Old 08-23-2013, 12:10 PM
Former Vendor
4WDHARDWARE's Avatar
What motor and trans are you running? That will be a big determining factor in what kind of power loss you'll see. The new 3.6L Pentastar motor has an awesome amount of power for a Jeep. The older 3.8 is kind of sluggish in the power department, however the 4.10 gears will really help out.
I would expect you to loose some power and maybe a MPG or two, but nothing too serious. I went from the stock 235's to a 33" tire and saw around 1 MPG loss in town and barely anything on the highway in my 2012 with the 3.6L
Hope this helps!
-Zach
Old 08-23-2013, 12:14 PM
SergeantChuck's Avatar
He has a 2007. I have the same year and did the same thing when I first bought my JK. I also had 4:10s. Your gonna loose a couple MPG. But its a jeep. You didn't buy it for gas mileage.
Old 08-23-2013, 12:29 PM
Mpierro1221's Avatar
I have a rubicon with 4:10 and 35 inch tires I get 13 on the highway and about 9-10 in the city
Old 08-23-2013, 02:57 PM
Hope this helps!
-Zach
Yes, I have an '07 with the 3.8. I have made a few engine modifications that have helped it gain slightly noticeable power. I get between 22 and 23 MPG on the highway and usually close to 17 in town. Of course I didn't buy it for good gas mileage, but I'm also always looking to save a buck or two where I can.
Quick Reply: Tire size question
