Towing Capacity 2D vs 4D
Old Jan 22, 2008 | 10:47 AM
  #41
Originally Posted by mcds99
Some how the dealer charged me about $500 more then they should have.
So I told them to get a towing package for me, I was going to go after market.
I'll post what they add when it gets installed on January 21, 2008.
They installed the bolt on hitch and did wiring, now if they could have put the cap on with a little thought I would not have had to do it a second time.
They checked everything over all fluids (inc wsw and filed it), checked the allignment, they did a good job. They put my plates on with 4 count them 4 screws! Usually it's only 2. They put my locking gas cap on and my spare cover.
I think I owe them more donuts ;-)
Old Jan 30, 2008 | 09:21 PM
  #42
Skiorsurf's Avatar
Talking Towing capactity
Hey guys I think why the Jeeps cant tow more is due to the rear suspension setup. Its coil sprung instead of leaf sprung. All the trucks and even the xterra's are leaf sprung in the rear and thus allows greater payloads than softer coil springs. If you google the military spec Jeep J8 which is built off the 4 dr platform it is upgraded with leaf springs in the rear and couple other things to boost the tow rating up to around 7716 lbs!! Anyway hope this helps answer why our Jeeps cant tow more. BTW I have a 2007 unlimited, auto, with 4.10 gears and factory trailer tow package and it is rated to pull 3500 lbs, which it does just fine. There is no heavier duty radiator or auto tranny cooler in front of it either. Jeep also has a towing guide on their website at http://www-5.jeep.com/vehsuite/TowingGuide.jsp
Old Mar 7, 2008 | 09:11 AM
  #43
archie0010's Avatar
I have a 2 door Sahara. Does anyone think I might have a problem Towing a 5,000lbs boat from the dry dock to the boat ramp? the dry dock and boat ramp are located on the same property!
Old Mar 9, 2008 | 12:44 PM
  #44
LinkSync's Avatar
Default Stock Info
Originally Posted by 08red6spd
Just wondering why the towing capacity is so different for the 2D(2000max) vs 4D(3500 max). I figure that the wheelbase matters somewhat but it seems like a big difference over a little longer vehicle.
Check here for stock info:
https://www.jk-forum.com/forums/stock-jk-tech-12/trailering-info-jk-sevice-manual-31646/
Old Mar 9, 2008 | 04:16 PM
  #45
csims723's Avatar
Default Here is a thought
take a look at how the hitch mounts to a cross member in the rear of the JK. Now take a look at how the hitch has side wings that mount to the frame and distribute the weight better on the Liberty. You get better load distribution on the hitch with the side wings to mount to the frame. It might have to do with the mounting to a frame cross member to show the diffrence of our towing capacity versus the Liberty. As for the 2d vs. the 4d I am gonna have to fo with the weight on the front tires also. But who knows I am just a firefighter not an engineer. Chris
Old Jul 13, 2009 | 09:39 PM
  #46
bostonMA's Avatar
If it has a 2" receiver and the wiring plug it has the tow package.
If your JK only has the hook, no tow package.
You can get a 2" receiver that bolts on for less than $100 and a cheap wiring harness if you need to tow.
Old Jul 13, 2009 | 09:52 PM
  #47
ronjenx's Avatar
Sorry, it has nothing to do with the difference in mounting mentioned here.
In both cases, the load is conveyed to the frame side members. It doesn't matter if it is through a hitch beam, or through the rear cross member.
In fact, the rear cross member looks more substantial than the smaller beam on the type of hitches you describe.
A Jeep engineer who posted on another site said the difference in tow capacity between the JK and Liberty was engine cooling capacity. The air flow through the JK radiator is not enough to cover all situations while towing.
Bottom line (from an actual Jeep engineer):
The difference between the JK 2dr and 4dr towing capacity is vehicle length.
The difference between the JK and other Jeep platforms with greater towing capacity is engine cooling capacity.
Old Jul 13, 2009 | 10:28 PM
  #48
ronjenx's Avatar
Originally Posted by weaver1371
It has an aftermarket bumper, but there is no wiring harness. So I'm guessing it doesn't have the tow package. Does that mean my towing capacity is lower than 3500lbs? I'm looking at buying a popup camper and just want to make sure I don't ruin the JK pulling it.
The towing capacity is listed in your owner's manual. Pick out the configuration which matches your Jeep.
The categories are: Engine/Transmission; Axle; Model.
Old Jul 13, 2009 | 10:37 PM
  #49
axel's Avatar
towing capacity for the 4d in belgium is 3500 KG
Old Jul 13, 2009 | 10:44 PM
  #50
ronjenx's Avatar
Which engine/transmission?
