Towing Capacity 2D vs 4D
Old Jul 13, 2009 | 10:51 PM
  #51
axel's Avatar
Originally Posted by ronjenx
Which engine/transmission?
3.8 with auto ( i have the rubicon ) but all 4 doors models are the same here in towing capacity ( dieselcrap and gas ).
most of the time all US vehicles have more towing capacity than they allow in belgium but this time it's the other way around.
i pull my competition rubi on the trailer and thats over 3500 KG ( 3750 kg ) i just put it on cruise controle 110 km/h and let it go
Old Jul 13, 2009 | 10:59 PM
  #52
ronjenx's Avatar
Originally Posted by axel
towing capacity for the 4d in belgium is 3500 KG
So, that's 7716 pounds, over twice what they are rated here.
Now THAT can't be explained by anything posted in this thread.
Old Jul 14, 2009 | 12:39 PM
  #53
Yea, the guy I bought my Jeep from also told me of the increased towing capacity for the JK in Europe. I am not sure how they come up with that number. I have an Unlimited Rubi with 35s and pulled a pop-up with a dry wieght of 1850 and a loaded weight of approximately 2800 from Sacramento to Zion in Utah. Prior to the trip I put airspring 1000s, a transmission cooller and a Prodigy brake controller on the JK. During some long climbs the JK did heat up and the coolant temp guage went to the 3/4 mark on the dash guage. Big Rigs passing as well as wind caused quite a bit of sway. The JK also felt terribly underpowered although I think a regear would help alleviate some of the problem as I have the stock 4.10s If I knew then what I know now, prior to the trip I would have definitely got a weight distributing hitch with sway control as well. Before this trip I looked at my JK and thought it could pull more than its rated specification of 3500, after the trip I would not go over 3000 lbs with a lift and M/Ts.
Old Jul 14, 2009 | 01:11 PM
  #54
sin52's Avatar
Originally Posted by Skiorsurf
Hey guys I think why the Jeeps cant tow more is due to the rear suspension setup. Its coil sprung instead of leaf sprung. All the trucks and even the xterra's are leaf sprung in the rear and thus allows greater payloads than softer coil springs. If you google the military spec Jeep J8 which is built off the 4 dr platform it is upgraded with leaf springs in the rear and couple other things to boost the tow rating up to around 7716 lbs!! Anyway hope this helps answer why our Jeeps cant tow more. BTW I have a 2007 unlimited, auto, with 4.10 gears and factory trailer tow package and it is rated to pull 3500 lbs, which it does just fine. There is no heavier duty radiator or auto tranny cooler in front of it either. Jeep also has a towing guide on their website at http://www-5.jeep.com/vehsuite/TowingGuide.jsp
The FJ can tow 5,000# and it's not leaf sprung...I know because I installed a lift for my buddy on his. AND his wheel base is 106"
and my wife's pathfinder can tow 7000#.
Old Jul 14, 2009 | 04:13 PM
  #55
Mr.ZAP's Avatar
Yeah but an FJ cruiser has about as much flex as a ford taurus hahaha
Old Jul 25, 2009 | 05:46 AM
  #56
CerOf's Avatar
My old '02 WJ was 6500lbs and it is coil sprung.
My JK has the electronic sway control. Never felt it activate but our pop-up has sway control on it.
Old Jul 25, 2009 | 06:00 AM
  #57
kendallrob's Avatar
I live in Miami so I don't have any problems with hills or mountains, that being said I would have no problem towing 6000lb + with my Rubi. I have towed a lot of boats with many types of vehicles and I cannot see why it would be a problem on flat terrain.
Old Jul 25, 2009 | 06:07 AM
  #58
ronjenx's Avatar
3500 KG = 7716 lbs.
Could that be the Gross Combined Weight Rating, which would include JK, trailer, passengers, and cargo?
