track bar
Old Oct 28, 2015 | 06:57 AM
07 Rescue Green's Avatar
Veteran: Navy
Default track bar
Anyone recommend a good track bar? I can't find any stock ones except mopar.
Old Oct 28, 2015 | 07:30 AM
munir's Avatar
You should be able to get the stock takeoffs for dirt cheap if you want stock. Other than that, there's tons of companies that make heavy duty or adjustable ones. Check out the Teraflex one for example, pretty beefy
Old Oct 28, 2015 | 08:25 AM
jedg's Avatar
Vet Army
What's wrong with the Mopar OEM track bar?
Old Oct 28, 2015 | 07:20 PM
Veteran: Navy
nothing is wrong with the Mopar, it's just that I want something better than stock for the same price.
Old Oct 29, 2015 | 04:11 AM
jedg's Avatar
Vet Army
If you're still at 2.5" of lift and have a raised track bar bracket on the front axle, then the OEM is your best bet. They have bonded rubber bushings at each end so they stay quiet and don't need the maintenance that the other types of ends will.
Old Oct 29, 2015 | 06:23 AM
Veteran: Navy
I am still at 2.5" but have added a leveling kit. I don't know if I have a raised track bar bracket, do I need one? Someone recommended a moog track bar but I can't find one for the jk. Thanks for your input.
Old Oct 29, 2015 | 08:30 AM
jedg's Avatar
Vet Army
So post a picture of the front axle from hub to hub. That'll tell us.
Old Oct 30, 2015 | 10:08 AM
Veteran: Navy
I took a picture of both ends then read your post again, if this is not enough I'll take another pic. Here they are.Click image for larger version
ID:	628779Click image for larger version
ID:	628780 Hopefully they show up.
Old Oct 30, 2015 | 10:31 AM
jedg's Avatar
Vet Army
I took a picture of both ends then read your post again, if this is not enough I'll take another pic. Here they are.Attachment 628779Attachment 628780 Hopefully they show up.
Yeah, it looks like you have a raised track bar bracket on the axle side.
Old Oct 30, 2015 | 11:00 AM
Veteran: Navy
ok, thanks. I ordered a mopar bar, they aren't cheap.
