transfer case stuck in neutral
Old 09-01-2011, 12:28 PM
orig93gt's Avatar
Default transfer case stuck in neutral
So i was at the beach today, drove through some loose sand in 4Lo with the rear locked, everything was going great, I even dragged a honda cr-v out that had no business being out there, then on the way back I unlock the rear and tried to shift back in 2wd, but the transfer case level just broke free and flopped back and forth from 2wd to 4H to 4L with no resistance. Apparently the t-case got stuck in neutral, because although I could feel the trans engage, I could not get any power past the t-case. So long story short a friend towed me to the parking lot with his pickup and a flatbed took my jk to the dealer. Now, is it just me or is 10,000 miles on a 2011 a little low to be having failures like this. I'm still waiting to hear back from the dealer as to how long they'll have my rubi. Anyone else run into anything like this? Thanks-
Old 09-01-2011, 12:38 PM
Noxian's Avatar
could be the shift linkage, i hear they are prone to breaking on the JKs, not sure if they resolved it on 2011s.
Old 09-01-2011, 12:51 PM
orig93gt's Avatar
i figured it was something simple like that, I just hope they fix it quick. If it is prone to happening atleast the parts will probably be in stock
Old 09-01-2011, 12:56 PM
Ronson's Avatar
There is a plastic clip on each side of the cable. Have broke mine a few times and now carry extras. If it happends to you again you can shift it at the transfer case by hand just watch out for the exaust pipe found out the hard way.
Old 09-01-2011, 01:29 PM
rozzman10's Avatar
been there done that. get under the Jeep and have someone sit in it and wiggle the 4wd lever and you should be able to see the linkage flopping around.
JeepPilot10's Avatar
Very common. Below is the part number. They are about $1 and you can snap it on with no tools. I keep several in the car.
Transfer case linkage bushings - 68064273AA
Old 09-01-2011, 01:31 PM
rozzman10's Avatar
did you just order a hand full from the dealer?
Old 09-01-2011, 01:35 PM
Vladimer's Avatar
I had the same thing happen on the trail, the design is very bad which results in this little plastic clip holding the cable to the rod on the transfer case. I now carry spares so I don't have to go through the same processes to get it back into 2 high. Up here in Canada they charged $2.40 per little piece of dinky plastic. Heard of folks getting it for as cheap as $0.30 in the states.
Old 09-01-2011, 01:42 PM
rozzman10's Avatar
GEEZ! they are really diggin deep into your pockets! haha
Old 09-01-2011, 02:23 PM
Vladimer's Avatar
No kidding, with markup I was expecting $1.00 or something but when he told me $2.40 I was like , talk about a markup. That's %800 off of the $.3 AND the usd is generally weaker
Not like the couple bucks is going to kill me, but the drastic increase didn't make me happy
Quick Reply: transfer case stuck in neutral
