Transfer shifter loose???
Originally Posted by Weeds
The trick to getting the bushing in is to put it in hot tap water for a couple of minutes. Then put it through the cable end and on to the shaft last.
I was struggling until the hot water. I went together I was pissed because I hadn't thought of it earlier.
This just happened to me yesterday, 2009 JKU. Dropped at dealership this morning since its under warranty. Great write-up though. Eventually that warranty will run out and if it happens again I can bypass the dealer and do this myself.
Great write up. Had mine replaced twice already too. The second time, I watched as the tech at the shop replaced the plastic bushing. Simple but aggravating... Definitely smart to grab some extra bushings and keep them with you. I think the heat plays a factor in weakening that plastic bushing over time. As little as I shift into and out of 4wd, I should not have had to replace that twice already.
Originally Posted by 303rubi
Saw this thread a few mths ago and went to the dealership and bought a few of these.... Broke on the trail last weekend. Had it fixed and running in ten min.
Ok boys I have a folllow-up! Headed out on the trail. My son goes to switch into 4wd and the lever is loose. I went through this in April of 2012 and had the replaced the crappy $0.30 piece under the console. I took the center console off.....it's fine. Look under the Jeep and discover they use the same piece at the transfer case. Definitely installing a Advanced Adaptors linkage!!!!
Bringing this back from the dead, but it was the most useful thread for me. Drill out the stud, then after the linkage is back on just put a cotter pin through it. Mine just broke while I'm in vacation, gonna do that if I can find a drill somewhere.
