Transmission stuck in 2nd
Guest
Posts: n/a
Just got my 2010 Rubicon and took off road to figure out the 4x4 stuff. Somehow the auto transmission got stuck in 2nd gear. I could not figure out why the thing would just not really get going. Then a hot oil indication popped up on the digital read out. Let it cool and drove it home. The next day it was still stuck in 2nd. Turned it off and then restarted it and wala. Back to normal.
Has anybody had the same issue.
Ditto, what you are experiencing is "Limp Home Mode". The trans will do this to avoid further damage when the fluid gets too hot among other things.
If you have a code reader look for code P0218 it would be a trans overheat code. I have not done it yet but I am looking at the Trans cooler mod. Search the write-ups for destructions.
Had "limp mode" happen a couple times took it to the dealer, had the P0218 code. Dealer says "your shift points are off, we'll reset it" haven't had it happen since but I'm still skeptical and want the aux cooler. (Don't know why they didn't include it from the factory considering it is set up to tow)
Pat
Pat
Just left to go to 4wheel parts and got on the highway and damn thing was stuck in second. I just installed an aux cooler so I don't think the transmission was overheating. Plus, I started it, left the house and drove one mile before I got on the highway. I'm confused....
Checked the fluid and it was right on...I have it sitting in the garage with the battery disconnected and hopefully it will work...
I just went through this same thing on my JK a few weeks ago. I got the P0731 error. Stuck in second - Its a limp home mode. There are 15 different causes for this error.
Ended up being the solenoid pac. Changed it and now it words fine. Fortunately, you only have to take the transmission pan off. Good time to service your tranny as well.
