Transmission stuck in 2nd
Old Nov 29, 2009 | 10:41 AM
nwjk's Avatar
Push in the CLUTCH! Works everytime for me...
Old Nov 29, 2009 | 11:07 AM
Mariner's Avatar
"Push in the CLUTCH! Works everytime for me... "
X 2 I personally enjoy the do it yourself transmission
Old Nov 28, 2010 | 11:34 AM
AirDWN's Avatar
Originally Posted by JEEP THRILLS
sounds like limp mode. similar to human limp mode, you wanna go but the body doesn't. usually happen when the trans. fluid is to hot. were you taking it easy or driving like you stole it
My JK went into limp mode because I dropped in a new battery with much higher cranking amps. It wasn't the transmission fluid because I had already checked the level a couple days ago and it was full. It also was about 50 degrees outside that morning and my Jeep had been sitting outside all night in 20 degree weather, so it wasn't an overheating problem.
All I did was let my JK sit in the driveway for a minute then I cranked it back up and drove it down the street again. It shifted like normal. If it had still been in limp mode my next step would have been to disconnect and reconnect the battery again.
Old Nov 28, 2010 | 02:00 PM
SLIM_SNOOPY's Avatar
Arrow
That is a new one , regarding a higher amperage battery, so long as the battery is a 12 volt automotive battery it should not make a difference. Amperage is A reserve capacity as such cc a's " Crank Case Amperage" the higher the better, especially in the cold conditions where a battery is known to be under the most stress compared to summer conditions.
Old Nov 28, 2010 | 02:25 PM
jcs07jk's Avatar
X2. Agree with above, higher amperage battery shouldn't have any effect on electronics. Now if you hooked up a second battery.... That could be a different story if not done right
Old Nov 28, 2010 | 07:48 PM
joe002's Avatar
Hey nwjk and Mariner, maybe you can help out Lone Wolf 87: https://www.jk-forum.com/forums/show...ns-won-t-shift.
Old Nov 28, 2010 | 08:17 PM
AirDWN's Avatar
Nevertheless, my JK didn't go into "limp mode" until I had changed the battery. The previous battery that came with my Wrangler died after the first cold snap about a week back. The neighbor had to jump me off so I could make it to work on time. Later that day I cleaned the posts and wires and the battery lasted a few more days.
You'd think jumping the original battery may have tripped some kind of fail safe device but it didn't. You'd think after having disconnected both positive and negative wires to clean everything up and reconnect them would have caused some kind of electrical issues but it didn't.
Furthermore, I flipped the switch a few times to get the code for engine warning light I received a while back. I got the code P 20553 something or other. Disconnected the battery a minute and reconnected it. Engine light disappeared, code disappeared--in fact, I got a "DONE" reading, then nothing but dashes--my Jeep worked fine. But with the new battery, I switched batteries and all of a sudden I'm in limp mode city. I've had the old battery disconnected plenty times for various reasons and never had limp mode issues. I switch batteries and get a limp mode issue. No big deal really. My JK is a damn rock. Still truckin' on down the road like an M1 Abrams tank.
