Trunk door extends past 90 degrees and smashes tail light. Please help!
The retention bar isn't designed to be a stop. It is there only to hold the gate open. The stop is in the hinges.
The way the bar is designed, it actually aids in decelerating the gate to some degree if it is allowed to swing open freely.
If the gate flies open hard enough to break things, it's because the operator allowed it, or caused it, to fly open.
I would take this opportunity to start a DIY project! Couple holes (1 in tub, 1 in gate), some bolts, some lanyard measured carefully. And you have your fix!
Please enplane on how you are opening the rear gate. Walk us through the process. Because it sound like the door and taking allot of stress from you opening it.
Are you parked on a slop and letting the gate fly open? I am not trying to say its your fault. I know Chrysler if full of problems. But i want to tend to lean to user error.
The first time it broke, I was on the side of the street with the right side of the car (the direction the tail gate opens) in the gutter. Not the actual gutter, but where the pavement ends and the sidewalk begins. So it was hardly a slope at all. The second time, was when my dad was driving the jeep after he picked it up from service and he said it broke in our driveway which has no slope at all. The 3rd time was in the exact same spot as the first except the trunk door was already open. I wasn't opening it and letting it go, the trunk was simply open to 90 degrees where it is supposed to be and when I leaned on the bumper to reach in the trunk, the bar broke and the tail gate went swinging. Im not sure what to do anymore.
That is exactly what I'm planning on doing, but I still want it fixed to like new again. I've had it for less than 4 weeks
AS others have stated, the tail gate stop is part of the 2 hinge assemblies. If they broke the first time when it happened and the dealer did not replace them you will continue to break things. Look at your hinges and see if the stop is intact. The door should open to 90 Deg. and stop.
Have you tried fabricating your own limit strap? I have a 2009 and the factory strap stops it. I know it sucks the bar from the factory keeps breaking on you, but maybe if you fabbed something up you wont need the bar. I do agree though, it should function as designed.
