Wet carpet
Old May 3, 2013 | 02:11 PM
Lang25's Avatar
Default Wet carpet
On my passenger side floor board when I lifted up the carpet it was soaking wet. Any thoughts what this could be? 2011 4dr wrangler
Lang25's Avatar
I mean carpet was soaking wet when I lifted up floor mat
Old May 3, 2013 | 02:17 PM
BagOfDoorknobs's Avatar
I had the same issue. There are a number of threads in the forum about this, including one by me. At the end of it all, I took mine into the dealer and they fixed the seal around the top right of my softtop. Been good ever since. Your mileage may vary ...
Old May 3, 2013 | 02:43 PM
JKJA10's Avatar
Mine was from the windshield header gasket.
Old May 3, 2013 | 03:09 PM
LACAPITAN's Avatar
I have the freedom top, and when it rains heavy I would get water dripping in from the front center point between the two front panels and on the right corner of the passenger side panel. Take a look at your gaskets around the roof. They might need some reinforcement/replacement.
Old May 3, 2013 | 03:33 PM
Juice Box's Avatar
It is the seal in the A Pillar. I will try to post a link to useful info if I can find it.
Old May 3, 2013 | 03:34 PM
Juice Box's Avatar
https://www.jk-forum.com/forums/stoc...-floor-272004/
Old May 3, 2013 | 04:00 PM
kh202's Avatar
My 2012 did that too. I have since cut the carpet out of the fronts only, and just run the floor mats in the front. SO much easier to clean and you won't miss having carpet under your seat
Old May 3, 2013 | 05:02 PM
Lang25's Avatar
Thank you. I believe it's the seal in the A pillar. It's been poring for the past few days in sunny south florida. Ill take It to jeep tommrow and let them deal with it cause I still have warranty
Old May 4, 2013 | 05:07 AM
swanny297's Avatar
My 2013 is going in on Monday for the same thing on the drivers side
